Horsepower vs. Torque ?
(03-06-2015, 06:52 AM)Rebel73_imp Wrote: I think torque is more directly correlated with acceleration, and horsepower more with top end speed.
torque and horse power are the same - energy generated by the engine. You are on your bicycle in first gear you generate more torque to climb hill. On 6th gear you generate more horse to go fast on downhill. Same you, same energy
From Carthrottle.com
"Where horsepower determines how fast a vehicle can travel, torque at the wheels determines how quickly that speed can be reached. The greater the torque figure, the faster the acceleration."
http://www.carthrottle.com/post/the-diff...explained/
The two are closely related, but not exactly the same thing.
(03-06-2015, 10:17 AM)Rebel73_imp Wrote: From Carthrottle.com
LOL I think that's what I said in post 2 Celebrate
Horsepower does work and is what accelerates the vehicle. Torque is a simple force and can be increased or decreased without a change in horsepower. Torque X speed = horsepower. Neither one is energy.
(03-06-2015, 11:05 AM)Dakota_imp Wrote: Horsepower does work and is what accelerates the vehicle. Torque is a simple force and can be increased or decreased without a change in horsepower. Torque X speed = horsepower. Neither one is energy.
I don't understand why anybody even talks about horsepower. To elaborate a little bit on what Dakota said:
Horsepower = Torque x RPM
If you know the torque curve, then you know the horsepower curve automatically. The confusion between torque and energy is that they share the same unit, the newton-meter (http://en.wikipedia.org/wiki/Torque#Units). Torque is a measure of how much force is transferred to the crank each rotation, so you multiply by how fast the rotations are to get the total power.
ok I'm no engineer but the new BMW s1000rr makes 83 ft lbs of torque and 193 horsepower
a Harley Davidson electra glide make 95 ft lbs of torque and 76 horsepower
The new Indian Chieftan makes 119 ft lbs of torque no reported hp figures I can find
I'm thinking the Harley will pull more weight as evidenced by it GVWR, but the BMW is going to run a heck of a lot faster through the quarter mile, and regardless of massive torque figures the Indian isn't going to be much quicker through the quarter than the Harley
The weirdness of comparing these numbers is because they're peak values. A Harley (and maybe an Indian?) hits that peak very early and then tails off. Torque at high RPM generates big peak horsepower. 83 lbs of torque and 193 horsepower on that BMW means the torque keeps going in the high range; you hear people talk about 'pulling in any gear' and that's what they mean.
My question is why do engines make torque in pounds feet and when you are torqueing a bolt its in foot pounds?
(03-06-2015, 12:23 PM)Lord Popgun_imp Wrote: My question is why do engines make torque in pounds feet and when you are torqueing a bolt its in foot pounds?
Perhaps one is a measure of resistance and the other a measure of overcoming resistance.
If I recall correctly, scalar vs vector. From my perspective, both are the product of force and distance.
  Oil Filter Torque ohiorider_imp 11 741 11-18-2017, 03:58 AM
Last Post: SportsterDoc
  Rear axle torque question. jdvalero_imp 10 990 03-21-2017, 09:29 PM
Last Post: jimgl3_imp
  Horsepower postoak_imp 35 2,296 09-27-2016, 04:50 AM
Last Post: use2b_imp
  Horsepower..IF the Ferret 50 3,021 10-26-2015, 06:04 PM
Last Post: gbpack89_imp
  Torque Wrenches Chapomis_imp 7 481 03-26-2015, 06:38 AM
Last Post: Chapomis_imp
  Chip Beck Explains HP vs. Torque for Mr. Ferret ChipBeck_imp 36 2,559 03-20-2015, 02:56 AM
Last Post: thessler3_imp
  Torque specs for Engine Gaurds metalmaven_imp 3 847 03-19-2015, 01:08 AM
Last Post: metalmaven_imp
