tank protection
(05-03-2015, 09:35 PM)Setchman_imp Wrote: I just finished installing mine on a 2014 DLX the other day. I had installed the regular Tankslapper film on my last bike and it worked just fine. This time I decided to try the upgraded XPEL film. If you want the ultimate in transparency, this is the way to go. I know that it is more than double the cost of the standard film but unless you know it's there, you don't even notice it. You would have to physically point to the edges to show someone else that it's on your tank. It's hard to see in the picture but you can just make out the edges.
The installation was pretty easy, though. If you don't already have a squeegee than I would recommend springing for the 95mm Turbo Squeegee for $5.69. I no longer had whatever I had used on my last bike so I needed something new. What I would have spent on something locally wouldn't have saved me that much money and this Turbo Squeegee really is a great tool, much better than what I had and designed to work specifically for this application.
Use soapy water like the directions say and it should go on just fine. The first time is a little intimidating because your sure there's no way this film is going to go on smoothly and lie flat as you try to work it around the curves but it eventually does. Just keep it wet and keep working it out with your squeegee and even your hands. Just like a screen protector on your phone, it takes a day or two before it's completely dry and smooth. It looks great once it's done, or should I say it "doesn't" look great!
Here's the direct link to the CB1100 Tankslapper page:
[url=https://thetankslapper.biz/oc/index.php?route=product/product&product_id=409&search=]Tankslapper for Honda CB1100
Setchman, are you sure the picture you show has the Tankslapper on it? It looks amazing, I can't see it at all. My issue is not with the tops of the tank near the seat, but on the sides where your legs have a tendency to rub the tank, again near the seat. And this product fills that bill? And what Expel did you use? The gloss one or the matte one?
Tankslapper has a three piece available. The one in the middle appears to protect your tank where the front of the seat rubs up where a boot can easily scratch it during an on off drill. The other two pieces are oval cut and serve like the rubber knee pads you see on Triumph Bonnieville's. So yes it is just that.
Here's a better picture. You can see the separation between the top and side pieces better.
[url=http://s1124.photobucket.com/user/kruegerhome/media/1EK_5618-002.jpg.html][Image: 048645c024cc874850e2d0a0bbf0e2df.jpg]
If you want absolute transparency then get the gloss. Although I've not seen any installed, I'm sure the matte version would clearly show itself.
I was skeptical at first but this XPEL film really is amazing stuff. I know I'm repeating myself but if you and I were standing right next to my bike and you didn't know I had it on my tank, I don't think you would ever notice it. Just today I removed the center piece because there was one little area that was bugging me and the only way to fix it was to take it off completely.
I thought for sure I was going to ruin it as I was taking it off. It is on so firmly that I thought I was stretching it way too much to the point of damaging it. I got a heat gun and warmed it up a bit and that helped a lot. I took the piece and cleaned both sides with warm, soapy water, reapplied as per the instructions and it looks better than the first time.
And yes, the side pieces are more than big enough to cover the entire area where your legs rub up against the tank.
Did you use the XPEL gloss or matte finish?
(05-06-2015, 01:03 AM)EGAlvarez_imp Wrote: Did you use the XPEL gloss or matte finish?
Gloss. It's as thin and clear as I think you could ever get.
Can the XPEL film be repositioned indefinitely? I put the regular Tankslapper film on my Bonneville because I didn't trust my abilities with the 3M film. My film has become stained, however, and I have been unable to clean it. I wrote to Tankslapper and I was told to try cleaning it with a high-speed polisher, which I don't have.
You did a great job with the film install.
I believe it can. At the very least, it can be removed and repositioned enough times to get it right. The XPEL film is supposed to be much easier to maintain and kept looking good. I think you'd find it's a much better product than the regular Tankslapper film.
There was a scrap piece of film included with the kit so you can practice before you apply the actual pieces, if you're concerned about your technique.
I've been impressed enough by the XPEL film that I bought some bulk film to make a couple pieces for the front of the tank. I will almost certainly have to remove and reposition it a few times just to get the shape right so I'll post a follow-up when it's done, hopefully within the next few days.
Thanks. I look forward to your followup post.
I went with the matte finish tankslapper. I applied to the sides only (for now). I love the way it looks!
[url=http://s1216.photobucket.com/user/metalmaven/media/HONDA%20CB1100/20150509_171836.jpg.html][Image: f5acd3c89afc30ed7c4fe00d56460c5c.jpg]
That is cool, but I'm curious if it is more of a satiny black finish or silvery like the picture suggests? How do you think the color would appear if it were on a red tank?
  Personal injury protection on your moto: just add it zbillster_imp 23 1,599 08-23-2019, 03:22 PM
Last Post: zbillster_imp
  Whitehouse tank dimensions vs CB750 tank dimensions spartanheed_imp 2 310 04-27-2019, 05:40 PM
Last Post: spartanheed_imp
  Anyone wrap their tank with paint protection film? apex1_imp 11 761 07-18-2018, 08:15 AM
  Need More Wind Protection? Offroad 9 477 07-13-2017, 12:04 PM
Last Post: EarsOnWheels_imp
  Protection gear for the bike gcarper_imp 0 151 09-26-2013, 11:14 PM
Last Post: gcarper_imp
