Threads: 2
I appreciate everyone's opinion and I thank you. The reason I want ABS is because of the environment I ride in. I live in a high traffic area of NJ. I grew up riding in NYC. On a smaller and lighter bike ABS is the way to go. The technology is nothing new and should be on every bike. Do ss lines help? I believe they do. I say this from experience. I've been riding for 39 years. Does rider training help. Absolutely! Are the brakes on the standard sufficient. Probably. But if there is that one time that ABS will help me in a situation, I'll take it. My other ride is an F6B. It doesn't have ABS but the brakes are linked. Another feature that Honda could put on more bikes for better braking.
Threads: 186
(08-23-2015, 11:10 AM)ff73148_imp Wrote: (08-23-2015, 07:41 AM)kmoney_imp Wrote: I don't really know that SS brake lines will really improve the braking significantly vs. the ABS model. The 4 pot calipers on the standard are still great in terms of power and modulation/feel (they are probably actually better than the 3 pots on the 2013 ABS, and IIRC are identical on the 2014+). Honda definetely didn't cheap out on the components on either model.
(08-23-2015, 08:14 AM)the_undecider_imp Wrote: Standard brakes are phenomenal. I think if you are concerned with not having abs, installing steel braided lines is not going to make up for the perceived shortcoming of the standard brakes. In fact, I find the standard brakes so responsive, easy to modulate, and with lots of feedback that adding braided lines might take away from the ability to easily modulate the brakes which is less safe on a non-abs equipped bike. Modern brake lines are not that of yore. They are internally reinforced, so you see only the rubber layer on the outside. They will last a long while.
Try to test out a standard and see what you think of the brakes. Unless you are used to riding supersports with radial mounted Brembos, I can't imagine anyone wanting for more.
You make a good point about changing to ss lines and interfering with the brake set up. I wish I could test a standard but dealers are unwilling to provide test rides.
Frank
(08-23-2015, 09:04 AM)redbirds_imp Wrote: The bike I had before the CB (Moto Guzzi Breva 1100) had braided lines and Brembo calipers and they were fantastic but not one whit better than the brakes on my non-ABS 2013 STD. The brakes on the CB are superb.
You honestly feel the brakes on the stamndard are as good as the ABS on your Guzzi?
My Guzzi was also non-ABS. I don't dispute the advantages of ABS and I would have ABS on my CB if it had been available. I have been riding for nearly 50 years and have seen the great advances in brake technology evolve. Braided lines are a fine feature but I cannot believe that they would make any significant improvement in braking on this particular bike.
(08-23-2015, 09:09 PM)ff73148_imp Wrote: I appreciate everyone's opinion and I thank you. The reason I want ABS is because of the environment I ride in. I live in a high traffic area of NJ. I grew up riding in NYC. On a smaller and lighter bike ABS is the way to go. The technology is nothing new and should be on every bike. Do ss lines help? I believe they do. I say this from experience. I've been riding for 39 years. Does rider training help. Absolutely! Are the brakes on the standard sufficient. Probably. But if there is that one time that ABS will help me in a situation, I'll take it. My other ride is an F6B. It doesn't have ABS but the brakes are linked. Another feature that Honda could put on more bikes for better braking. It's funny how this is different for every rider. Personally, I'm not a ABS fan. In fact, I considered the the ABS on my DLX the only strike against it; an unnecessary complication and expense. Who knows...maybe someday I'll have to maximum brake in the rain and I'll be happy it's there. I guess I'm one of those guys who believes that if I ever find myself in a position to require maximum braking and/or the magic that ABS promises to deliver, then shame on me  I swear, in all my years of riding, including a 10,000 mile loop around the U.S., I've practiced max braking in parking lots and such but have never had to employ it on the road (knock on wood...)
Likes Given: 816
Yes everyone is different. With regards to stainless steel brake lines " transforming" the bike ( as well as the "recommend tire of the day" and aftermarket rear shocks) I have tried all of the above over the years and find them never living up to the claim for me. I can't tell aftermarket shocks from stock, tires to me are tires, they roll, they turn they keep the shiny parts off the tarmac ( although some last longer for me than others) and stainless brake likes don't make my brakes feel any different. None of them "transformed" my bikes into anything they weren't before. Not saying YOU won't feel anything any different, but I certainly didn't, and felt foolish every time I sprung for expensive parts that seemingly made no difference. The only thing that has made any noticeable difference for me was a fork brace on my 750 Nighthawk, which cured a shimmy I was having. other than that I seem to get no benefit for spending money on expensive aftermarket stuff, which is why both of my CB1100s, and my ST 1300 have remained basically bone stock. I'd rather spend my money on gas, oil, and oem motorcycle consumables.
As far as ABS goes, my 13 CB didn't have it, my 14 CB does. That's how they came. Have not had to use it on the 14 yet, or had it activated that I could tell even though I have panic stopped a couple of times.
Note and I believe this is true contrary to certain published reports, the 13 and 14 ABS are different. The 13 is a 3 pot linked system and the 14 is a two pot non linked system.
Threads: 10
You should try a set of the EBC HH pads, they made a difference in my brakes. I am planning on doing SS brake lines, but I am going to wait until next spring when the brake fluid is due for another change.
Threads: 6
ff73148 you said it all in that one sentence: "If there is one time that ABS will help me in a situation I'll take it."
I'm a big fan of ABS, had it on several previous bikes, but I also own a '13 without it!
Buy what makes you happy and gives you peace of mind and don't worry about all the riders who will tell you they are either better, faster or smarter than an ABS system.
Threads: 41
Likes Given: 39
I've put stainless steel or braided lines on many bikes, mainly to achieve the right length, but don't find they offer any improvement over stock rubber covered lines. Withe either stainless or rubber covering, the brake fluid is contained in the same hard nylon line within. The stainless and rubber only provide abrasion protection.
My CB1100's brakes are as good as anything I've tried, giving lots of power and good lever feel.
Threads: 44
And "good brakes" is a whole 'nuther animal from ABS brakes, too.
The front brakes on even my '13 standard model are excellent - and this comes from a guy who rode just about only sportbikes for over 30 years before buying the CB. They are strong, have good feel, and great bite. In fact, I remember reading in one of the bike's reviews that Honda used the same calipers that were used in one of its superbikes a few years back. I have no proof of that, but I can tell you that they haul this bike down from speed extremely well. Some may love/require ABS as well, and I won't argue that point here, but that's an aspect apart from the actual performance of the brakes otherwise.
My feeling is that you won't be disappointed, either way you decide.
Threads: 29
(08-24-2015, 03:28 PM)pekingduck_imp Wrote: I've put stainless steel or braided lines on many bikes, mainly to achieve the right length, but don't find they offer any improvement over stock rubber covered lines. Withe either stainless or rubber covering, the brake fluid is contained in the same hard nylon line within. The stainless and rubber only provide abrasion protection.
My CB1100's brakes are as good as anything I've tried, giving lots of power and good lever feel. Yeah. I've read/heard from lots of people that most of the difference that people feel from SS lines is mostly from having a freshly and completely bled system after the install.
