Design Problem, Rear Wheel shifting to left
C
(12-02-2015, 11:49 AM)Lord Popgun_imp Wrote: Or just look on the part listing. I think the 14 is different from the 13 as they changed the axle size so the hole would be a different dia.
You can look at the parts listing as much as you like but if the collars are different thicknesses and installed incorrectly then it won't help. If you think that collars cannot be installed incorrectly then think again. I have seen collars on a front wheel installed incorrectly and the mechanic trying to work out why the caliper assembly was harder to get back on than off (but it did go on). All I am trying to do is set this blokes mind at rest by trying to determine the distance from the swing arm to the driven flange if the wheel is installed correctly. Not hard really.
I'd be happy to post a photo of my 14 but one look at my nasty chain and you'd ostracize me for life.
Actually, I don't have a caliper and wouldn't be able to provide any sort of precise measurement.
(12-02-2015, 12:44 PM)LongRanger_imp Wrote: I'd be happy to post a photo of my 14 but one look at my nasty chain and you'd ostracize me for life.
I can understand that. I don't polish my headers, or anything else much really. Just wash the bike when it gets covered with road grim. The chain I do wash in Kero and lubricate. I have been bitten once by chain neglect.
As for measurement, precision is not required. To the nearest mm would be OK.
Ptero,
I think we're arguing the same thing. Of course they could be installed on the wrong sides. I was just trying to answer the question about if they are the same on abs and non abs. Left and right side are diff. part numbers, but are the same for all both abs and non abs. One set of part numbers for 13s and another set for '14s.
I like your method of measuring the spacing. I think I'll do that and annotate my manual for future ref. when taking the wheel off.
It looks to me like the photo is taken from a slight angle. The design distances from wheel to swing arm don't necessarily need to be equal. What's important is that the wheel centerline aligns front to rear.
Not difficult to check. IMO, the bike is fine.
^^^^ No worries mate, just trying to help this bloke out. I think, by looking at the assemblies, it would be difficult to get it all back together if those collars are different and arse about. However it has been done on a front wheel and some blokes are unstoppable "if it can be done".
THank you all of you, it is so good to have so many CB1100 fans here
Gentlemen,
After examining my CB11 and then looking at these photos something looks screwed up. My rear tire is perfectly centered under the rear fender and between the rear shock lower mounts. Was this bike purchased brand new or did it have miles on it? Most likely the rear wheel is out of alignment causing the rearmost part of the tire to be offset to the right.
Chip
(12-03-2015, 03:06 AM)ChipBeck_imp Wrote: Gentlemen,
Chip
I agree Chip. It's either that or photographic distortion. If you read [url=http://cb1100forum.com/forum/showthread.php?tid=7440&pid=113601#pid113601]my previous post you will see I have measured the distance between the outer edge of the left wheel nut and the right side of the driven flange. As mine is a '10 model it may be different to that on a '14 model. This distance, plus a simple run-out check on the rear tyre, would tell Mockhoff whether his bike is safe to ride.
Ptero,
I measured mine and got 10.1. guess that's close enough. I, like Chip, have looked at the pics and my bike and back and fourth a few times and either you or Chip must be correct.
Maybe he should do this: http://www.cb1100forum.com/forum/showthr...#pid108779 and get back to us/you.
  Website Presentation problem rbike_imp 3 379 11-18-2023, 06:13 AM
  My probable design for my new gas tank- PowerDubs_imp 22 1,759 05-04-2021, 02:47 AM
Last Post: yugo42_imp
  Reverse shifting Elevenminusoneblade_imp 5 496 12-30-2018, 06:20 PM
  A question about wheel weights. FLYTYM_imp 24 1,897 12-01-2018, 03:55 AM
Last Post: Jim21680_imp
  Thought I had my first problem Swartzracer_imp 13 889 07-25-2018, 09:20 AM
  Problem with RLETs Carlos_El_Pato_imp 15 1,053 05-28-2018, 04:21 AM
  Capo’s CB Has Left The Building Capo 6 430 05-18-2018, 01:53 PM
Last Post: Guth_imp
  Trailer wheel chock Buff7mm_imp 4 389 05-10-2018, 08:57 AM
Last Post: Buff7mm_imp
  '17 EX tank design pdedse 70 4,011 04-03-2018, 05:42 AM
Last Post: VLJ_imp
  gear shift problem 2017 model ? alprider 12 1,419 03-26-2018, 05:04 PM
Last Post: alprider
