Brake light trigger switches adjustable?
(12-13-2015, 06:48 AM)Riko_imp Wrote: hmm curious about this too, is there a picture as to wich screw and micro screw you are refering too?
[Image: 91b8e5956d983ce7b942afa155382d0f.jpg]
I don't have a picture for what I did but it should take less than 1,000 words to explain. There is a single mounting screw that uses the large hole you can see on the picture. I loosened it a little, allowing me to rotate the switch body enough towards the lever to make a fingertip touch on the brakes actuate the switch. Then I tightened it down, and it has stayed put for about 500 miles since I did that. I didn't need to file any plastic as MininSX reported he had to do-- I just rotated the switch body a little. Maybe there is something on the switch blocking adequate rotation on some installations. I can't imagine that a very slight filing of the plastic could damage anything, and might give you the range of motion you need to get the result.
At the NYC Motorcycle show, there was a lecture about maintenance checklists, and the speaker said brake light adjustment is one of the most overlooked safety checks that should be done regularly. As Ferret said, make sure it's not "always on" but also make sure it comes on before the bike actually starts to slow down.
According to the service manual, the front brake light switch actuator is not adjustable. The rear is. If the front is not working correctly, it should be a warranty repair.
That's exactly what I figured, it's out of warranty and what's it gonna hurt to try it. It took very little filing to give the switch just enough room to adjust it so that it works.
  A procrastinator soon to pull the trigger WhatYes_imp 26 1,623 02-14-2022, 07:19 AM
  LED Tail/Brake Light? Whoops 20 1,488 04-14-2021, 09:41 PM
  Anybody running a pulser headlight,brake light module? FLYTYM_imp 8 559 06-06-2018, 01:12 PM
Last Post: FLYTYM_imp
  I pulled the trigger today tinboatcapt_imp 12 781 07-03-2017, 07:44 AM
Last Post: tinboatcapt_imp
  Trigger Finger Todd_K_imp 12 760 09-05-2014, 08:49 AM
Last Post: jodyz_imp
  Switch the switches ..14 DLX the Ferret 30 1,817 03-21-2014, 08:04 AM
Last Post: Deanohh_imp
