LED Tail/Brake Light?
So I just installed the Vizi-Tech Supabrake 3 and it seems to be working great so far. The bummer with having an incandescent brake light bulb though is it is much slower to cycle when flashing.
I understand that there are issues with the turn signal/running lights when swapping to LED, but would it be possible to just upgrade the brake and tail lights so I can increase the pulse intensity on the Vizi-Tech relay?
Has anyone swapped those out and if so, what did you replace it with?
Yes , after 5 years on this forum never have been able to post pics
Can you guys attach a photo to an email? Do you have a file of jpeg photos in your PC?
I have never done it from a phone but they tell me it's real easy in tapatalk
Have you tried following Max’s post here, http://cb1100forum.com/forum/showthread.php?tid=12717?
(04-08-2021, 10:36 PM)obleo_imp Wrote: Yes , after 5 years on this forum never have been able to post pics
Without having to attempt posting a picture, do you have a part number or website link for the bulb perhaps? I have done a fair amount of searching using the Honda part number with LED and haven't found squat outside of a traditional bulb.
I ordered the service manual which I am hoping will state a generic bulb number I can get just about anywhere which might help me locate a generic LED substitute. So no worries if you don't have a part or link. Thumbs Up
Whoops, is it the tail light you’re after? The 2013 Service Manual says it’s 12V — 5/21W. I suspect the 2014 is the same.
5/21W is a universal tail/brake light bulb used the world over. Just buy any LED bulb being sold as an automotive tail/brake light bulb. Before you do though you might take the existing standard bulb out and check the two bayonet pin locations. Some manufacturs use differing offset bayonets.
For example, check out this bulb here. You need to look for something like this but matching the bayonet locations that you have on your existing bulb.
https://www.ebay.co.uk/itm/P21-5W-LED-50...4842622332
(04-09-2021, 06:48 AM)Tev62_imp Wrote: 5/21W is a universal tail/brake light bulb used the world over. Just buy any LED bulb being sold as an automotive tail/brake light bulb. Before you do though you might take the existing standard bulb out and check the two bayonet pin locations. Some manufacturs use differing offset bayonets.
OK, will give that a try. I thought there was a standard bulb designation, perhaps something like "3049" or the like. I will pull the bulb and go to an auto parts store and see what models match, then see what I can find online that is an LED replacement.
Thanks!
(04-09-2021, 06:26 AM)Cormanus_imp Wrote: Whoops, is it the tail light you’re after? The 2013 Service Manual says it’s 12V — 5/21W. I suspect the 2014 is the same.
I think you're right. From the different parts schematics at various parts houses on the web, the 2013 and 2014's seem to be the same bulb and wattage.
Here's what i use at the moment, works fine but the difference between running and brake light is a bit less than i would have liked, still ok though and should last a fair bit and the light output is fine;
Things to watch out for is the dual contacts in the base and the wattage.
Designations are bay15 s ( single contact 15 mm socket ) and bay15d ( Double contact ).
I think bay stands for Bajonet socket Automotive And i give up on the y bit, could be a size unit for the socket.
You want the bay15D variety like in this picture.
just got some spares for the future too.
Here is a link that says it is an 1157 and shows an LED replacement: http://cb1100forum.com/forum/showthread.php?tid=3348
There are most likely more if you search around.
  Tail bag recommendations? Scotty_imp 16 1,131 09-09-2020, 05:08 AM
  Anybody running a pulser headlight,brake light module? FLYTYM_imp 8 524 06-06-2018, 01:12 PM
Last Post: FLYTYM_imp
  2017 Tail Light Housing Aka Tsubasa_imp 8 607 05-29-2018, 07:20 AM
Last Post: cbkev_imp
  Brake light trigger switches adjustable? SailorRider_imp 12 950 12-17-2015, 01:53 AM
Last Post: mininsx_imp
  What is better than a tail bag to avoid the tank bag scratches? Nemo_imp 11 701 10-27-2015, 12:14 AM
Last Post: jrns_imp
  Tail of the Dragon conditions aircooledwrench_imp 21 1,289 05-22-2015, 11:27 PM
