CB Cold Weather Start-Up
(01-20-2016, 05:05 AM)The ferret_imp Wrote: Well it's not an either or. Take out the battery, take it in the house and put it on a tender. That's what I do for my riding mower. Next best thing would be to take it out and take it in the house and let it sit on a piece of carpet or cardboard or plywood, not on a concrete floor. Finally I don't see any difference in unhooking it and leaving it in the bike, or just leaving it in the bike hooked up. In either case it's going to get cold, discharge and not receive any refreshing charge for as long at it sits there..
I see. Thanks!
I think the question is why does it discharge if it's not connected to anything?
Batteries at rest lose charge whether connected or not .. something about positive ions and all that...otherwise you wouldn't need a generator or alternator or trickle charger to keep it up. I've heard as much as 1% per day but that may have been old technology lead acid filled batts. They do not store an infinite amount of power for an infinite amount of time. Even when being charged daily they eventually will no longer hold a charge. Nature of the beast.
Cormanus,
Google battery self discharge and 'local action'. That should explain it, mostly.
Yup. Batteries, if left to their own devices, will discharge. There are things going on in the battery and their chemistry that cause this.
You can test this by leaving your battery out for the season, then just before it's time to ride, hook it up to a real charger that shows just how far it needs to charge. It will help you if your battery is kept very cool (but not frozen) during its' down time.
(01-20-2016, 07:21 AM)The ferret_imp Wrote: Batteries at rest lose charge whether connected or not .. something about positive ions and all that...otherwise you wouldn't need a generator or alternator or trickle charger to keep it up. I've heard as much as 1% per day but that may have been old technology lead acid filled batts. They do not store an infinite amount of power for an infinite amount of time. Even when being charged daily they eventually will no longer hold a charge. Nature of the beast.
That's about right for a flooded cell battery. Actual discharge rates also vary with temperature (hotter temps, higher discharge). You're correct that newer technologies do better. Sealed AGM batteries self discharge rate is about half of the flooded cell rate. Lithium batteries are pretty good in this respect, discharging at only 2-3% per month.
Thanks, fellas.
I'm in the camp that removes the battery, takes it in the house, leave the bike sit for the Winter. I 'tend' to the battery every few months. Once it warms up, let rain wash the salt off the road before your take the bike out.
Just the way I operate.
(01-24-2016, 02:25 AM)sourdough44_imp Wrote: I'm in the camp that removes the battery, takes it in the house, leave the bike sit for the Winter. I 'tend' to the battery every few months. Once it warms up, let rain wash the salt off the road before your take the bike out.
That's the way I do it too with all my bikes except the CB. I have an Optimate pigtail connected to the battery which is easy to access so I leave the battery in place and hook up the charger once a month for 24 hours.
The other batteries are stored in a cool dry place and once a month they are cycled through with the charger for 24 hours.
In all cases the chrger goes into "float mode" very soon indicating that the batteries have lost very little charge.
Come spring, I'm in no hurry to get out there before the road debris has been washed away,
  Cold Weather Riding Yata-Garasu_imp 79 7,207 01-24-2026, 12:21 PM
  Best Weather App for riding? ymtnpoah11_imp 22 1,508 02-04-2023, 03:32 AM
  Well That’s a Fine Start The Flying 1100_imp 17 1,102 08-15-2021, 05:30 AM
Last Post: max
  Massive weather front lashes eastern Australia Rocky_imp 15 1,183 03-23-2021, 06:49 AM
  Unusual day weather wise here in NE Ohio ohiorider_imp 4 518 12-02-2018, 11:41 PM
  Everything is running well - then the weather turns bad ohiorider_imp 11 1,099 11-02-2018, 12:02 PM
Last Post: ohiorider_imp
  Start up idle / procedure? el duque_imp 5 368 03-29-2018, 08:39 AM
Last Post: el duque_imp
  Begining Motorcyclists: Start Slow or Get Right In It? specialist8 13 731 08-16-2017, 12:26 AM
Last Post: CA200_imp
  Come on weather ... cooperate! ohiorider_imp 8 612 03-06-2017, 11:29 AM
  Bad weather = no seat time. SCCBrider_imp 12 950 04-14-2016, 05:41 PM
