Dent Removal in the DMV
My friend will pay for it no prob, not sure of his insurance status. I guess will spin by Dent masters in Tysons and have them take a look. Otherwise, just wait for a used 2013 tank to be listed. Of course, the decal route is always an option -- although the Conan airbrush art is tempting. Or Vampirella!
I notice that Samurider has 2014 model tanks for sale (pricey too). Does anyone know if those will fit a 2013?
2014 tanks will not work on a 2013. The fuel pumps are different. Both in mounting and pressure.
(04-05-2016, 05:58 AM)AzBob_imp Wrote: Paintless dent repair often involves heating the area. I'm relatively certain this won't work on the tank because of explosions and such. A crease is nearly impossible to remove with the paintless method anyhow. Creases are very difficult to remove, paintless or not.
Exactly my experience.
It's extremely pricey, but I believe Samurider has gas tanks for sale...your buddy's insurance ought to have to cough up the bucks for the replacement, since repair isn't exactly the best approach to a motorcycle gas tank.
I don't know what the situation is with your buddy, but I was brought up with a very distinct credo: if you borrow something, you return it in as-good or better condition than you got it. If it's not, you make the fix so that it IS. If he's not volunteering to pay, or report it to his insurance, I wouldn't feel too badly about reporting it for him...this isn't being a douche, it's just plain old what's fair.
(04-06-2016, 12:20 AM)Lord Popgun_imp Wrote: 2014 tanks will not work on a 2013. The fuel pumps are different. Both in mounting and pressure.
Not so. The gaskets are the same on all of the tanks and they didn't change the shape of the 2014 STD tank. They did change the fuel system a bit in 2014 and altered the pressure, but the 2013 fuel pump will fit either tank just fine.
The DLX (EX) and the STD use the same fuel pumps.
What this means is if you want to install a DLX (EX) tank on a STD of any year, go for it. I would just use a new fuel pump mounting gasket to be on the safe side.
2013:
http://www.hondapartshouse.com/oemparts/...-fuel-pump
2014 STD:
2014 DLX (EX):
Well Randy, I'm embarrassed! I could have sworn that we had determined the pump mount was different. I was wrong. And I should have checked the fiche before posting. Thanks for correcting. Slinking off now...
(04-06-2016, 09:50 AM)Lord Popgun_imp Wrote: Well Randy, I'm embarrassed! I could have sworn that we had determined the pump mount was different. I was wrong. And I should have checked the fiche before posting. Thanks for correcting. Slinking off now...
I wasn't trying to scold you sir...lol. Just making sure the correct information is out there for people to make an informed decision is all. Big Grin
Lol
I'm good! Beer Just Blush
Correct info is always good. Just don't want to lose what little cred I do have here. If any Tongue And I usually do look pretty closely at the parts fiche.
So to get back on thread, a new tank can be had through Samurider, but also from the online parts dealers, like the one Randy posted, or others, at a few hundred dollar discount from the dealer. Plus, you can sell your tank to someone and recoup some of our money. Post up a pic of the dent so we can see it, if you would.
Or if you are lucky, like I was when I dented mine, from another member who swapped out his tank.
OK, Some good info here, please see if I have this straight: A 2014 STANDARD tank will fit a 2013 but use a new fuel pump mounting gasket.
Is this right? If, so opens up some options...
Thanks again guys, great resource here.
The service manual says to use a new gasket when installing the pump.
FYI: I did not when I changed my tank, but the bike, and thus the gasket, was new. I have no problems. YMMV. Gaskets are cheap.
Edit to add: I changed from a '13 tank to a '13 tank.
(04-07-2016, 10:24 PM)Supervillian_imp Wrote: OK, Some good info here, please see if I have this straight: A 2014 STANDARD tank will fit a 2013 but use a new fuel pump mounting gasket.
From what I can tell you can use either tank, but I have not tried the larger tank so don't take that as gospel.
   Water spots removal Bosti 7 604 06-25-2023, 03:20 PM
Last Post: Yata-Garasu_imp
  EX seat removal tpo12001_imp 1 229 06-03-2023, 12:03 AM
  Turn Signal Removal Nibis_imp 10 642 12-28-2021, 03:38 AM
  Seat removal sharkey_imp 3 243 08-27-2016, 05:02 AM
Last Post: sharkey_imp
  OEM Rear Shocks spring removal AllenM_imp 7 1,010 08-16-2014, 03:13 PM
Last Post: gossman_imp
