Chrome Browser Trouble
(10-04-2023, 02:39 PM)Cormanus_imp Wrote: Interesting ... I've just restarted my computer, opened Chrome and had the same problem.
I used Chrome this morning and had the issue but it worked fine after I refreshed. I try not to use Chrome, Brave is still having issues, I "reported a broken site" with them I'll see what happens.
I use a few different forums and most seem to use the same platform, this forum seems to be a little different.
Chrome has been rock solid for me since its inception, and on Windows, Linux, and Android. Heck, even on my iPad junk it just plain works.
The CB1100 Forum site service uses an antiquated web framework, but nonetheless, seems to work reliably on my browsers including Edge and Firefox.
i cant view the site well either just text and white
This is most likely your browser trying to load the site by default using HTTPS. The site however was not setup to support that protocol for whatever reason. Most browsers also now hide the protocol (HTTPS, HTTP) at the beginning of the URL as a way to make the URL more friendly and instead display a lock symbol or some other cute little indicator which can make it confusing to determine under what protocol the site is being loaded.
Try typing "http://" before the "cb1100forum.com" in the address bar and see if it loads the site properly with images and the correct CSS formatting. If that works, then try searching how to "always load a site using HTTP" for your browser, or alternately, create a bookmark for the site and edit the properties and change the URL to HTTP if it saved it as HTTPS.
I have had this problem for a while. I go to the bottom of the page, select "lite (archive) mode" and click full version at the top of the second page.
Cumbersome, but it works.
Ben
... the generous founder of the site donates his personal resources and time to manage the service. Life sometimes leads us down other paths that need more attention.
I already fixed my 3 computers presently used.
Iphone was never "infected"
I have the exact same problem. I tried going to the Chrome system page and deleting "cb1100forum.com/forum/" as recommended in a different post and it didn't work for me. Any other suggestions?
In the chrome address bar type in
http://cb1100forum.com
If it doesn't work, right click on chrome address bar and delete s from https, and then delete everything that is after .com including /
so will bring you back to
and press enter and follow CB1100 Forum < may need to enter again
I am not computer expert, so my explanation may not look so professional
If it's fixed, in the google address bar will show you a little triangle with ! inside of it Not secure
If it doesn't work then let me know, so will provide pics?
This is how I fixed mine.
Some members have expressed that FireFox solved their pain.
  Can't get forum to load properly Google Chrome? Davidjill_imp 5 596 07-26-2024, 07:29 PM
Last Post: Davidjill_imp
  Trouble starting my CB when I when I use the on/ off button to shut of My CB. I calipo223_imp 26 1,840 08-04-2021, 11:08 AM
Last Post: Rox_imp
  Chrome mudguards question Mixagon_imp 25 1,920 02-11-2021, 04:07 AM
  Trouble Getting Honda Parts? DAC 12 1,052 05-07-2020, 09:37 AM
Last Post: Mtneers
  Trouble getting on the site KiowaEagle_imp 14 860 08-27-2019, 01:12 AM
Last Post: Frulk_imp
  Triple Trouble Ack-CB11_imp 10 735 01-15-2019, 12:48 PM
  Chrome Care Jim21680_imp 12 934 11-10-2018, 11:41 AM
  The Chrome in the 14 Std Nemo_imp 16 1,209 03-15-2016, 09:28 AM
Last Post: pwh421_imp
  Little chrome things BikerBob_imp 4 436 07-29-2014, 06:05 AM
Last Post: dBuster_imp
  DidI tell you how much i love chrome head pipes? the Ferret 17 1,149 04-15-2014, 12:10 AM
Last Post: rboe
