Threads: 10
Hello. Has anyone had this issue. If I turn the on/ off switch off to shut off my CB it’s hard to start back up when I hit the starter button. The battery/ alternator light is on as well until the CB runs a bit. It seems I’m lucky my CB turns over. If I turn off my CB with My key and leave the on/off button on My CB starts right up, no battery/ alternator light on. The 2 clip wires are attached in that area. Thanks I advance for any help. Calipo223
Threads: 36
Can't explain the difference but I never use the on/off switch. I just leave it on. After hearing stories of them failing I figure why tempt fate?
Threads: 245
Likes Received: 1,207 in 518 posts
Likes Given: 978
If you're only experiencing this problem when you use the kill switch, and it doesn't occur when you use the key, or when the engine is cut off by the side stand switch, then the first thing I'd do is disassemble the kill switch and clean the contacts to see if that eliminates the problem.
Threads: 1
I have exclusively used my killswitch since I bought my CB1100 8k miles ago and haven't ran into this issue.
Just some reassurance that this didn't break your bike. I agree with Gi60 that a closer look at the switch itself may be warranted. Maybe start by having the health of the battery checked since that's easiest.
The kill switch should be exercised regularly to ensure proper function and safety when you need it most.
Threads: 698
Likes Given: 792
there has been a history of issues with that switch on this board going back to 2013 or 14. Sometimes just cycling it off and off a bunch of times has fixed it (temporarily I imagine) but taking it apart and cleaning I believe was the fix.
Threads: 245
Likes Given: 978
I have the same issue with my hazard lights. I never have a cause to use them, so sometimes when I switch them on to test them, only one side comes on. If I cycle the switch a bunch of times, they'll both start to work.
Threads: 186
The kill switch on my CB was so sensitive that it would kill the engine if even lightly touched. I have always detested these totally useless devices, a common source of problems.
Threads: 19
Does sound like the kill-switch issue, I've notice people have had to mitigate those occasionally on the CB. Personally never had that problem, but I can see how it can be unnerving.
And I agree - they are probably redundant - and there are most likely better ways to switch the bike off, but for whatever reason they stuck, and are likely to remain.
Recently I was coming home from a long ride, going about 90 on a highway I was passing through a windy portion of the road and wanted to get into a bit more of a tuck, as I went down I noticed that my right bar-end mirror was pointing at the sky so as I reached over with my left hand to adjust it I accidentally hit the kill switch and the bike went dead, it took a split second to understand what's going on (it felt like a year, the feeling of getting cut at the waist and losing my ground sort of like when an airplane suddenly drops, pins and needles, cold sweat and chills), figured it out, knocked it back into ON and bike just bumpstarted itself and kept going like nothing ever happened, nonetheless - I blame the kill-switch lol
'14 CB1100 STD 5 speed
(08-02-2021, 02:05 PM)tod.branko_imp Wrote: Does sound like the kill-switch issue, I've notice people have had to mitigate those occasionally on the CB. Personally never had that problem, but I can see how it can be unnerving.
Yeah, the kill switch is there for accident safety, and not just for the rider, but for anyone rushing to help the fallen.
I have hit the kill switch too while riding and just flipped it back on to bump start the bike in-flight. Not very exciting and a dull inconvenience.
Maybe a future evolution will be to reliably utilize the IMU to signal a downed rider and kill the engine. I believe this is being done now by some manufacturers, but is not standardized.
