 Lumbago - lower back pain
Unfortunately this is a fairly common occurance for active men, and once it happens you are even more suceptible for it happening again. I have had it several times. First time I went to emergency ward of hospital where they administered a shot which helped tremendously but still required a couple of days of bed rest. I think its happened 2 times since which I did the moist heat pad, rest, ibuprophin routine. The thing is once it has happened, you never know when it is going to happen again. Pick up something wrong again and BAM! Backs out. It may be a couple years, but eventually when you least expect it, it will happen again.
I feel for ya Riko. It's certainly no fun. Get some rest, heal up, and then start being real careful about how you lift things.
thx for the heads up!
I tried to do a so called pelvic tilt...
Can't barely move upwards Undecided
(10-30-2016, 10:05 AM)Rboe_imp Wrote: You may have slipped a disc. If you're in the wrong position when you stressed the back with the lift you can easily (too easily if you ask me!!) slip a disc.
There are some things you can do to help (the classic, lay on your back, relax then, one leg at a time, slowly bring each knee up to your chin and hold for a minute or two, alternating between each leg. In the end you want to do both legs). It's a good thing to do as maintenance too.
If it causes more pain well then you gotta listen to your body and you should see a doctor. When it comes to your back, I have found seeing a doctor is a good thing as back failures give you the oddest symptoms that earlier experiences will fail to correctly deduce.
Welcome to old age. Big Grin
did some research bout slipped discs, and luckely I don't seem to have any of these symptoms:
Reading those I'm thinking yikes, thats like he** Confused
But as of now, walking and sitting is discomforting.
Laying down seems to be the only thing I'm good at now.
Ow and walking DOWN the stairs Smile
I could walk down stairs all day...
Riko.. Try laying on the floor on your back, with your tush tight against the front of your couch with your calves on the seat portion. Kind of like the position 1 of the pelvic raise above only your legs are resting on the couch cushion. The closer you can get your tush to the front of the couch the better. That position always helped me.
I can sympathize with all of this as I have a "tender" lower back too and have to be careful how I bend or lift.
It also doesn't help getting closer to your 80th birthday Tongue
Working the core tummy muscles are a great help; they assist the abused back muscles in keeping you upright.
Bulging and or ruptured discs tpically causes pain down the siatica, folded sock syndrome and a limp. For me, a slipped disc feels like a rod got jammed in the back and I can't bend very well. It's kinda scary (especially the sound when it slips back) but when I slip a disc I prop up a leg on something tall like a fence (sorta even with my waist), raise up the arms to my shoulders (sometimes with my fists on my chest), then while standing as straight as I can I twist away from the elevated leg as far as I can. Say about 2.5 revolutions (OK, slight exaggeration Big Grin ). No bouncing, just a good solid even pressure into the rotation. Repeat on the other side.
Sometimes this will pop the disc back - about a third of the time. The rest of the time it usually slips back later in the day or over night. Also a good one to do just because.
Some have told me that having a small gal from the far eastern pacific rim walk on your back in high heals is supposed to be good too but I have not tried that yet. Rolleyes
Have you asked her?
I don't understand the motorcyclists with all kind of over-the-top protective gear, and no simple kidney belt.
And on lifting the bike on the center stand: I often see riders who hold both handlebars while trying to do it. In that position, unless you are very tall, you are exerting a fair bit of downward force in a twisted and bent position, courting a spine injury. Instead, when lifting the bike on the center stand, leave the left hand on the handle-bar, but with your right hand grab something on the rear left side of the bike: passenger hand-hold, cargo carrier or similar. Then, while in nearly straight, upright position, step with your full weight on the stand foot-lever.
I have a nice alpinestar touring kidney belt... I like it. Recommend it.
(10-31-2016, 02:52 PM)rotor_imp Wrote: I don't understand the motorcyclists with all kind of over-the-top protective gear, and no simple kidney belt.
From now on THATS not even a certainty anymore to avoid a lumbago.
Am gonna look into those kidneybelts for sure.
Thx all!
But, Riko, having to lift the bike onto a piece of wood is what made it so hard.
  Lower back pain pdedse 31 2,402 03-09-2025, 11:36 PM
   I am back from hibernation Ennsync_imp 1 216 05-11-2020, 03:11 PM
  Needing to lower my cb Gremlinsteve_imp 13 850 11-27-2019, 07:20 AM
Last Post: Redbird_imp
  Fork lower paint/ plasti dip? HBFL_imp 5 439 02-13-2019, 09:15 AM
Last Post: DBM_imp
  Polymer CB lower engine case protectors Frulk_imp 1 201 05-07-2017, 01:41 AM
Last Post: aschem_imp
  Test Ride/ Wrist Pain Kung Fu Joe_imp 11 816 06-19-2015, 02:58 PM
Last Post: Kung Fu Joe_imp
  Rust on lower fork bracket LiveToRide_imp 134 8,947 05-12-2015, 05:23 AM
Last Post: Elipten_imp
  Lower Priced OEM Parts speedgeezer_imp 9 630 06-22-2014, 04:59 AM
  lower seat? ncgeezer_imp 7 651 02-13-2014, 03:38 AM
Last Post: AllenM_imp
  Do mods lower value? HikerToo_imp 17 1,007 08-05-2013, 12:01 AM
Last Post: Buffalorider_imp
