How Are New Bikes Handle Bars Positioned
(05-13-2017, 12:21 PM)BestStandard_imp Wrote: The '13s came in narrow crates with the handlebars removed:
https://www.google.com/search?q=2013+cb1...iZJRBMUfM:
The '14s were in wider crates and came fully assembled except for the mirrors. The batteries on the '14s were factory filled and installed, but the battery cables were disconnected and hanging out below the left side cover.
Makes sense. Thanks! I bet many were unhappy with dealer setup and Honda's answer was to install the bars at the factory.
2013 batteries were also factory filled but not connected.
What does factory filled mean? The batteries are AGM and sealed.
If it came in the bike but not connected, I know it has to come out for the dealer to install the lifting strap. I had to install mine as they forgot and just put it in the tool box. The service manager wasn't exactly happy with the mech when he found that out Smile
https://www.google.com/search?q=2013+cb1...=2#imgrc=_
wonder how they snag the pics? 4th row down on right bike with luggage is my bike, 5th row down white bearded guy sitting on bike is me (picking up my 13), 12th row down guy standing by bike is me (picking up my 14 dlx)
(05-13-2017, 08:35 PM)Lord Popgun_imp Wrote: What does factory filled mean? The batteries are AGM and sealed.
We are used to the AGM batteries that are shipped with a battery pack that gets filled and charged (YTX series), but our original battery (YTZ14s) is filled, sealed, and charged by Yuasa. It is shipped in the bike with the lifting strap around it, but if it is taken out to charge, the strap can be lost.
Since that battery is used on several Honda models, some (better) dealers will keep one on charge for that quick sale, and rotate it into a bike with a low battery, so the strap is easily overlooked.
As far as I know, only our CB1100 uses the strap. If by chance yours does not have the strap on it, you can take off the left sidecover and sort of push up on the bottom of the battery by moving the rubber flap under the battery box.
Something else curious - a lot of new Hondas use batteries that are the exact same size, but have different cranking power and amp ratings. Some are factory filled, some come with acid packs. The higher powered ones not only cost more, they can weigh a pound and a half more.
(05-13-2017, 11:29 PM)The ferret_imp Wrote: https://www.google.com/search?q=2013+cb1...=2#imgrc=_
Found the pictures. Somehow I had imagined a ferret as a small, slim, agile creature, but must be mistaken. That person was shaped more like me. Big Grin
About 4 years ago, I innocently mentioned I'd purchased an AGM battery (Yuasa) and was waiting for the dealer to add acid and bring the battery to full charge. Response from another forum. "If the dealer is adding acid and charging the battery, they didn't sell you an AGM battery, which comes fully charged and ready to use."
Rather than get into a debate on the forum, (not CB1300) I contacted Yuasa and indicated the discussion forum members were having. Here's the Yuasa response,which you may find interesting.
To summarize our conversation on lead-acid engine starting batteries ….
There are basically 2 kinds.
Conventional / Flooded: the type with individual removable filler caps, and a vent elbow / tube.
These batteries are typically see-thru so you can see what level the acid needs to be maintained to.
Only water evaporates. Acid can not evaporate. Thus why you only have to add water back into the mix.
and
AGM (Maintenance-Free): acid is Absorbed in the Glass Mat separators, and battery is sealed to the outside air.
Water never evaporates in this type of battery, thus why fluid never needs to be replenished. Furthermore the battery will be destroyed if you try.
These batteries are typically all black. They do contain acid, but they can be manufactured one of 2 ways from Yuasa…
Dry Charged; this is where the plates are activated at the factory, but then dried. The battery is supplied with a separate metered acid pack to use where you are ready to activate the battery for use in your vehicle.
You fill it, you SEAL it .. charge it 100% and you are done.
The other way we supply these batteries, in some cases is…
Factory Activated; this means we fill the acid here, and seal it for you. It is ready to go when you buy it. Only caution is age. When sitting around already activated somebody needs to make sure older product is rotated, and charged when need be, to prevent these batteries being useless when finally put in a vehicle. Some manufacturers only make Factory Activated because they do not have the ability to Dry Charge.
These batteries are not referred to as GEL.
GEL is used for deep cycle applications (trolling motors and wheelchairs)
Any questions, always feel free to call us, toll-free at 866-431-4784
Technical / Product Support Department
Yuasa Battery Inc.
I learned something new today. I hate it when that happens.
Ferret, tap on one of your pictures to enlarge it and you'll see that Google Search snagged it from the ST-Owners forum. You can then click Visit Page to see exactly where it came from.
Did you ever wonder how Santa and his helper hauls and delivers all those toys whenever Rudolph is sick:
https://www.google.com/search?q=2013+cb1...-lGjJmEsM:
[/quote]
I used to be small, quick and light..wrestled 105 pound class as a senior in high school, was on gymnastic team and ran cross country. That was 48 years ago. Get married, quit playing sports, have kids, finish all their meals, sit at a desk or behind the wheel for 40 years, grow old, have grandkids, finish all their meals when they are here.. and wala.. a more appropriate name would probably be Sloth instead of Ferret these days
Ooops wrong link... here's Santa finishing his run:
https://goo.gl/images/dqcsGq
  Stock handle bar specs mvk24_imp 6 637 07-06-2023, 09:22 AM
  Crash Bobbins or bars Maturecheese_imp 14 1,011 07-04-2022, 02:29 PM
Last Post: run-tmc_imp
  How many extra watts of accessories can the CB1100 handle? HondaFan_imp 13 1,217 05-23-2021, 11:28 PM
  Just purchased 2013 CB1100. Buzzy Bars ambbmw_imp 14 1,258 02-18-2018, 11:59 PM
Last Post: Marcosss_imp
  Handle bar diameter jdvalero_imp 2 298 10-25-2017, 07:48 AM
Last Post: flynrider
  Crash Bars for an other bike activedirt_imp 0 202 08-18-2017, 02:26 AM
Last Post: activedirt_imp
  Engine Guards / Crash Bars RonLyke_imp 93 7,465 06-02-2017, 09:55 AM
  Any interest in sissy bars? PowerDubs_imp 85 5,064 05-15-2017, 01:11 PM
  Clip ons or drag bars for a DLX? elemenopi_imp 7 1,087 03-22-2016, 08:53 PM
  Kury arms and pegs on OEM crash bars White Dog_imp 0 167 11-13-2015, 02:43 AM
Last Post: White Dog_imp
