Discolored exhaust pipes
In a way, it's good to know that my particular bike isn't having some lean running issues causing the splotchy pipes. I'll be googling for Optiglanz, and the Jet Cote solution looks pretty good, too. I guess I could jet cote in black and call my 2014 "Midnight."
Thanks for the responses.
Bob
My '13 std does the same. "Freckles" is a good description. Not too keen on it but I haven't been bothered enough to do anything about it...yet. Opyiglanz eh? Amazon here I come.
Yes, optiglanz, autosol or similar, my pipes were black at the top, i'm convinced it was a preservative that had not been cleaned prior to delivery to the first buyer, given the pattern.
Had to actually get in there with 1200 wet and dry to remove the substance and polish with a strip of old jeans wrapped around one pipe at a time with autosol but i got the result i wanted;
See before and after, and yes they colour up "gold" quite quickly.
Also did a test with a magnet and my stainless headers are slightly magnetic, i wonder how magnetic the double headers are because i remember the 4 exhausts of my cb550k3 were not very old when i had to replace them, so i like the stainless idea for longevity.
Max, that preservative was supposed to be cleaned off before delivery. Cleaning it off is in the pre-delivery setup instructions.
My pipes look like yours below the cleaned part.
Max, the shiny glance of your exhaust pipes will not last long. The dark spots will soon come back.
I rub some oil like Balistol on them after each ride and clean it off before I start a new one. It's akward but keeps the darkening away. Sometimes I polish them with Autosol too. As good as the 4 in 1 system is, that it doesn't keep its glance by itself is something I don't like so much, but I like shiny pipes, so nevertheless I play this never ending game....
Wisedrum
(12-09-2017, 07:10 PM)Cormanus_imp Wrote: In my opinion it was shabby of Honda to ship the 2010-2016 Standard CB1100s without double-walled stainless steel exhaust headers. Those fitted to the DLX/EX/RS models are much sharper.
However, being essentially lazy, I've accepted this curious design decision and am allowing my headers to discolour in whatever way they want.
For those unable to live with that choice, a product called Optiglanz has received rave reviews on this forum for its simplicity and efficacy.
Cormanus, my guess is that the double walled headers underneath the chrome plating are not constructed of stainless steel.
Guth, that's just my ignorance shining through! Perhaps I could rephrase it and say it was shabby of Honda to ship the 2010-2016 standards without headers that would retain their shine. It would be interesting to know if anything has changed on the 2017 standard.
(12-10-2017, 04:07 AM)ohiorider_imp Wrote: In a way, it's good to know that my particular bike isn't having some lean running issues causing the splotchy pipes. I'll be googling for Optiglanz, and the Jet Cote solution looks pretty good, too. I guess I could jet cote in black and call my 2014 "Midnight."
Bob
Yeah, single wall stainless pipes discolor naturally. I can see why you'd be concerned, though. If a double walled chrome pipe discolors like that, it's usually a sign of an overly lean condition.
I've found that riding in the rain tends to give the pipes a darker, spottier appearance. I don't ride in the wet very often, but have noticed the color change when I do. A bit of metal polish and elbow grease soon after will bring them back to their natural golden color.
You don't think so? I would have guessed that Honda would use stainless on the inner pipe. The main reason being the large amount of moisture that typically collects in an exhaust pipe. If they didn't use stainless, I'd expect to see some serious corrosion issues in a fairly short time.
Bob
No, mainly because I think if they had gone to the trouble of using stainless it would have been published somewhere. On the current CB1100 EX they point out the use of stainless steel spokes. But I've never seen it mentioned that they used stainless steel on the double wall exhaust headers. Maybe someone else has though and can share a link.
I asked right away because my 2014 st colored bad on the right side almost the first day,I was told it was normal and haven't given it a second thought sins. Gives it that old bike look. Might be what Honda was going for...
  Shined up Exhaust Pipes TwoBrothersBusa_imp 20 944 02-20-2022, 02:37 AM
Last Post: 2017EX_imp
  Polishing up the pipes Tom_imp 95 4,885 12-15-2021, 04:05 AM
   In Praise of Quiet Pipes Yata-Garasu_imp 48 2,831 12-03-2021, 09:49 AM
  Alternatives to Stock 4 into 1 Header Pipes? Yata-Garasu_imp 16 901 05-17-2021, 09:38 PM
  Brits To Tackle Loud Exhaust Pipes With Noise Cameras clearviewx 46 2,113 06-10-2019, 05:01 PM
Last Post: Bazbro_imp
  Cleaning the Exhaust Pipes ahm12_imp 16 776 05-10-2019, 12:12 PM
  Discolored pipes zippooriginal_imp 15 720 07-28-2016, 12:45 PM
Last Post: 4 Paws_imp
  Staintune Pipes Griso Guy_imp 2 184 02-24-2015, 05:02 PM
  DidI tell you how much i love chrome head pipes? the Ferret 17 799 04-15-2014, 12:10 AM
Last Post: rboe
  Different engines and pipes? ride4now_imp 17 941 06-17-2013, 10:32 AM
Last Post: Bonafide_imp
