5 or 6 speed? Gear indicator?
(04-17-2018, 03:43 AM)PAULIBIKER_imp Wrote: New 14 for $6500 or used 13 with 1200 miles for $4000? I like red and the black motor, so that’s a wash. 6 speeds and gear indicator are nice, but $2500 nice?
Yes, nice, but for me on the bikes that haven't had a gear indicator, I don't even notice it after a few rides; the brain takes over, you know what gear you're in.
I might not miss the indicator, but I'd certainly miss the sixth gear.
(04-16-2018, 11:09 PM)PAULIBIKER_imp Wrote: Been looking at 13’s and 14’s. Do they all have 5 speeds and a gear indicator? Leaning towards a black 14 but there is a low mile 13 close to me pretty cheap. Thanks
GENERAL info:
1. 2013 - 5 speed and ONLY neutral indicator, 5th gear = 1.111 (30/27) = NOT O/D
2. 2014 - 6 speed and 1-6 + N indicators, 5th gear = 1.074 (29/27), 6th = 0.964 (27/28) = 6th IS O/D
3. Honda did NOT modified 2013/5-speed tranny JUST by adding the 6th gear to 2014 !!!!!
4. Entire gear ratios for 2013 & 2014 are TOTALLY different. STUDY gear ratio for 5 & 6 speed tranny.
If you do not understand gear ratio/rpm correlation, ask somebody who does, PRIOR making your decision!! Gears are not just the numbers.
I do not intend to influence your decision.
Good luck Thumbs Up
pb
(04-17-2018, 03:04 AM)Bheezy27403_imp Wrote: Thank you papa Ferret for showing me the error of my ways. Thumbs Up
Papa????? Ferret.....I did not know his new nameTongue
ClapExcited
pb
2013 rider here. Upside to the 5-speed is that you shift 17% less than the 6 speeds. And who really needs a gear indicator when you have a tach? (that's the serious part of this reply).
See post 50
http://cb1100forum.com/forum/showthread....#pid198504
GENERAL info:
Good luck Thumbs Up
pb
ClapExcited
pb
ClapExcited
pb
That's cause I look like Papa Smurf ROFL
GENERAL info:
Good luck Thumbs Up
pb
ClapExcited
pb
ClapExcited
pb
ClapExcited
pb
ROFLROFLROFLROFLROFL
Thanks for having great sense of humor..
Worship
pb
I've never had a bike with a gear indicator before and I will admit it's nice to have but it would not be a deciding factor in my purchasing.
The 6th gear though is almost a must, I'm always looking for another gear on my HD and at one point I wanted to install a 6 speed trans but just couldn't afford it at the time.
The ECU programming is different as well.
I love my 13, but I'd love it a whole lot more with a 6-spd and a gear indicator. I'd absolutely go for that if it's an option.
Here's a good article if you're still undecided:
https://gizmodo.com/can-a-6th-gear-fix-t...1579761725
  Speed governor drewdavis_imp 4 568 08-27-2024, 05:49 AM
  Looks like the speed limiter is still on the '14. flynrider 38 3,415 06-12-2024, 05:31 AM
  ABS indicator fault kenred_imp 6 607 09-02-2022, 07:14 AM
Last Post: max
  Top Speed, 125MPH? HikerToo_imp 46 3,356 06-06-2021, 03:28 PM
Last Post: Rox_imp
  Will riding with prolonged speed limiter damage the engine?? zirconxi_imp 10 2,780 03-15-2020, 03:39 PM
Last Post: zirconxi_imp
  Triumph Speed Twin Obleo 5 582 01-14-2020, 01:15 PM
  Low-speed shimmy HondaJon_imp 24 1,634 11-10-2018, 11:36 AM
  2017 Honda CB1100EX, still top speed / rev-limited? DaSwami_imp 42 2,792 07-22-2018, 05:36 PM
Last Post: MaFiHa_imp
  For those of you wanting to defeat the speed limiter... Guth_imp 85 5,624 02-23-2018, 03:22 PM
Last Post: flynrider
  Yes Virginia, there is a speed limit. flynrider 52 3,609 06-04-2017, 01:27 AM
Last Post: chync_imp
