05-09-2025, 07:42 PM
Squelch the Squeek
05-09-2025, 09:07 PM
(05-09-2025, 07:42 PM)pdedse Wrote:(05-09-2025, 03:15 PM)Whoops Wrote: I think if this doesn't make a difference, the only thing I have left to try is a different pad composition. ... But what if I already wear those?
2017 CB1100 EX | 2024 Africa Twin AS ES DCT
Whoops i'm probably wrong but looking at your second picture with the underside of the calipers it seems that there are wearmarks on one surface ( the left part ) of the caliper.
The right hand one seems a bit recessed in such a way that that pad may not be supported? https://cb1100forum.net/forum/attachment.php?aid=192 Not sure if there is enough space to put some of that shim on those load bearing surfaces and see if there is a difference. Just one of those wild ideas that emerge from my subconscious mind.
05-10-2025, 05:44 PM
I have absolutely no squeal. I may just be incredibly lucky.
For what it is worth: I purchase only OEM pads and install them exactly as detailed in my Honda 2017 CB1100EX service manual. I use a great torque wrench to make sure everything is in compliance with Honda’s recommended torque. I clean the brake pads and rotors as part of my weekly bike detailing protocols. I use solvents recommended by Honda. I always apply the back brake first and then the front. I have a fork stabilizer on the front which definitely balances out weight in all scenarios. I welcome any feedback you care to share if you believe any of these items actually help reduce brake squeal. David
2017 Honda CB1100 EX
05-10-2025, 07:04 PM
(05-09-2025, 10:02 PM)max Wrote: Whoops i'm probably wrong but looking at your second picture with the underside of the calipers it seems that there are wearmarks on one surface ( the left part ) of the caliper. I saw those areas where it appears it was making contact. I did apply some grease there, but the shims are used up so hopefully grease will make due.
05-10-2025, 07:08 PM
I always wear earplugs when riding and keep my hearing aids in a small box.
I never heard any noise, but I can feel my bike perfectly.
"Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan® '14 CB1100 DLX, s/n 170, 42K kms - FOX® '14 CB1100/ABS, 134K kms - sold '13 CB1100/c-ABS - 56K kms - sold *Grand Chancellor*
05-10-2025, 10:18 PM
(05-10-2025, 05:44 PM)rdprdp01 Wrote: I have absolutely no squeal. I may just be incredibly lucky. I'm curious about the effect a fork stabilizer could have. Did you put it on at the time you bought the bike? (05-10-2025, 10:18 PM)pdedse Wrote:(05-10-2025, 05:44 PM)rdprdp01 Wrote: I have absolutely no squeal. I may just be incredibly lucky. The fork stabilizer was on the motorcycle when I purchased it. I did remove it to see if I could tell a difference, which was detectable. After I cleaned it, I reinstalled it and do not believe I will ever ride without it. It improves handling at all speeds, but particularly at slower speeds or when stopping. It “firms” everything up and for lack of a better description, lets me feel more connected to the front tire. I assume that stability has an indirect impact on braking, too. That said, I am not sure if my maintenance practices, Honda engineering, or just plain luck has enabled me to avoid the squeal endured by so many Members. During my research prior to purchasing the motorcycle, I ran across an article which described the difference in forks between the CB1100EX and previous models. Here is a link: https://www.motorcycledaily.com/2017/08/...e_vignette I have everything setup in a “neutral” riding position. I do lean slightly toward the front of the motorcycle. I am not sure if having my weight more evenly distributed over the motorcycle makes a difference or not. Hope this helps. David
05-11-2025, 02:59 PM
The 2017 brakes have squealed through history ... https://cb1100forum.net/forum/showthread.php?tid=519
05-11-2025, 03:06 PM
(05-11-2025, 02:59 PM)Cormanus Wrote: The 2017 brakes have squealed through history ... https://cb1100forum.net/forum/showthread.php?tid=519 Copy that. For the first time, I find myself actually lucky. I hope I continue to remain squeal-less.
The most sophisticated, smooth, perfectly engineered motorcycle I've ever owned. A pleasure in every way. |
« Next Oldest | Next Newest »
