Squelch the Squeek
In the latest episode of my attempts to Squelch the Squeek, I put a pack of adhesive shims on the original Honda factory pads that I removed in my first attempt to cure the problem.
Original factory front brake pads, cleaned and ready to go.
Calipers dismounted and cleaned to almost new!
Adhesive brake pad shims, 4 per pack.
Shims applied and cut to fit with a sharp knife.
After putting the pads and springs back in the calipers with some fresh new 3M silicone on the slide bolts, I pumped the brakes a bit to move the pistons back out and was ready to give them a test ride.
I took the bike on a ride up a local canyon and was very ginger with braking initially since these pads definitely aren't properly seated any longer. After running the pads gently for a while, I rode them in pretty hard coming back down the canyon. The squeal reduction with this attempt has turned out to be more effective than any other attempt I have made to date using all manner of goops, greases and pads.
However, I do note that while pushing the bike in the garage after getting back from my ride, the brakes seem to be dragging a bit. Not enough to make pushing the bike difficult, just enough to make a sound. I suspect that the thickness of the 4 shims combined with a set of pads that have barely any miles on them has made the brake fluid reservoir a tad too full. Since I am due for my annual fluid change, I picked up some Pro Honda DOT4 and will flush the lines and return the fluid to the proper levels and see if that remedies the minor drag issue.
2017 CB1100 EX | 2024 Africa Twin AS ES DCT
Very interesting, Whoops. I've given up on finding a fix and have come to terms with the squeal, even though it's a constant reminder of the "squeal like a pig" scene from Deliverance.  If you've seeen the movie, you know.  If you haven't...do not google that scene.  Don't.
Will be interested to hear how it turns out after you change out the fluid.
Great, now I will think of that scene every time I use my front brakes!
Honestly great movie, but one I try not to think of that often
'84 Honda Magna VF700 (Gone, but not forgotten)
'06 Yamaha VStar Classic 1100
'14 Honda CB1100 Std
(05-08-2025, 08:19 AM)Whoops Wrote: In the latest episode of my attempts to Squelch the Squeek, I put a pack of adhesive shims on the original Honda factory pads that I removed in my first attempt to cure the problem.
Theoretically possible, but less likely.
Most likely, homemade shims "ate" all the necessary clearance between the pads and rotors, causing the brakes to bind.
*First of all, without touching the front brake lever slide a thin sheet of notepad paper between all the pads and rotors....to check the clearance
*While still on a center stand, check that the front wheel can turn freely without any force or resistance...
*Open the brake reservoir cap, press the front brake lever a few times and check if there is any improvement.
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
Hi all, Whoops there is a chance that adding all those pads makes the shims a bit " springy " and cause the pads themselves not to retract the tiny amount to clear the rotors as Peter mentions.
This could be a bit of a problem if they drag and heat up some, just be aware of this but good to hear the progress, seems you are on the case!
Never gave this a thought but; what keeps the pads in place, is it solely the pins or do they use a part of the caliper as well to transfer the brake force to the caliper housing and keep them aligned?
Very nice photo's by the way!
Power of dreams eh? nice touch!
(05-08-2025, 03:39 PM)peterbaron Wrote: Theoretically possible, but less likely.
Was going to make a joint reply to you and Max, but the reply window doesn't seem to work like the old forum and I can't seem to link to a post number...
I can't slip a piece of paper between them, so they are definitely touching the rotors with the shims installed.
I can turn the front wheel on the stand without much effort, however the drag is creating enough resistance that the wheel doesn't continue to spin freely like it does on my Africa Twin, for example.
I will be changing brake fluid today and give that a try to see if it is actually over-full/over-pressured. I didn't attempt this yet until I am all setup to change fluid with the 60 or so towels I need to prevent damaging the paint with my klutzy hands.
(05-09-2025, 03:47 AM)max Wrote: Hi all, Whoops there is a chance that adding all those pads makes the shims a bit " springy " and cause the pads themselves not to retract the tiny amount to clear the rotors as Peter mentions.
I can guess you might be right as to the "springy" behaviour as the pads seem to consist of a woven mesh of synthetic, plastic-like fabric covered by a bit of a gummy rubber coating. Then the side that adheres to the back of the pad has an adhesive.
So far as the pads go, it appears to me that they hang soley on the pins and then only contact the retention clips along the top edge of the pads, as well as the open ends of the cylinders when applying pressure to the brakes. I wish I could fully know where the squeek is originating from so I can address that specifically. Like others have mentioned, it only seems to happen when you are going slowly just before you come to a complete stop, at about 5-8 mph I would guess. My thoughts are that the pads are actually chattering against the rotors creating a bit of a harmonic vibration rather than a squeek of metal on metal like you would hear in a car when the wear indicator drags on the rotor.
My next attempt was going to be trying some organic pads, but I can't seem to find a set that fits the 2017 EX.
(05-08-2025, 09:38 AM)pdedse Wrote: Very interesting, Whoops. I've given up on finding a fix and have come to terms with the squeal, even though it's a constant reminder of the "squeal like a pig" scene from Deliverance.  If you've seeen the movie, you know.  If you haven't...do not google that scene.  Don't.
*shudders*
Not a movie scene I cared to recall, thanks. Hilarious
When dealing with odd noises and other idiosyncrasies on vehicles, if I can't fix it it becomes a feature rather than a defect.
Been around longer than that! Cool
So I changed the brake and clutch fluids this morning and it made no difference. As Max and PB suggested, I do believe the softer texture of the SBS shims was compressing a bit on activating the lever, but then sprining back when the lever was released putting constant pressure on the pads to contact the rotors, like a really thin peice of foam. Off they came and back to the other set of Honda pads after cleaning everything up again.
This time however, I did look for anywhere on the pads, retention clip and calipers where the pads could be rubbing anything except the rotors and slide bolts. Then I took some Permatex green brake grease and used a q-tip like a tiny mop and coated the pistons where the touch the pads, the pads where the pistons touch, the slide bolts of course, where the bolts contact the retention clip, where the clip touches the top of the pad backing, and even what appears to be a bit of area on both sides of the pads where it looks like there might be a slight bit of rubbing on the calipers.
I think if this doesn't make a difference, the only thing I have left to try is a different pad composition. I would like to try a set of organic front pads, but it seems all I can find for the front is semi-sintered, full sintered HH or ceramic composites. Looking at the price of one rotor (over $500), I am not real eager to try pads that put more wear on the rotors. Anyone know who might make a set of organic front pads for a 2017 EX?
Whoops, Metal Gear is a local manufacturer of brake pads, discs, etc. I've used their pads and been pretty happy. I couldn't see that they sold organic pads for the 2017, but you could ask. https://www.metalgear.com.au/
