Going up 1 on the front sprocket
(08-20-2018, 09:18 AM)DBM_imp Wrote:
(08-20-2018, 06:20 AM)m in sc_imp Wrote: .. why? the motor is basically optimized efficiency wise at around 3-3500.
Thank you for the info. I was thinking 2500 rpm at 70mph would be perfect.
In my humble opinion, you'd be lugging the motor at 2500 in high gear. I consider 3,000rpm to be absolute minimum high gear rpm for my 'big' V-Twin Guzzis. The CB1100 is a completely different animal, but it shares its love to rev with the Guzzis. 3000 is my minimum for 4th, 5th and 6th on my '17 EX.
(08-20-2018, 01:19 PM)m in sc_imp Wrote: ^ this exactly
Quote:It is my understanding that peak fuel economy coincide with peak tq when tuned correctly- not taking into account wind drag which would increase load.
Like all my understandings- I could be wrong.
on a dyno, yes. but you are leaving out a LOT of variables as you alluded to. theory is great as a starting point.... but practical tests are where the truth lies.
"In theory, there is no difference between theory and practice, but in practice... there is!"
(08-20-2018, 10:02 AM)PowerDubs_imp Wrote: It will pull fine at 2500rpm cruising.
Want to go faster- down shift.
But to get there you will be giving up a good amount of grunt around town. You better like cruising at 70mph low throttle for long miles, quite often.
How are you adjusters all the way back stock? Chain worn out? How many miles on the bike?
My bike is a new 2014 leftover with less than 1000 miles. Chain tension is perfect but the adjusters are almost all the way back. I was wondering if this was the normal stock set up?
Not on my bike...
Might want to verify the front sprocket is stock. If it had been replaced with one less tooth the chain would require that level of adjustment and perhaps that’s why it seems like you need to change the rear sprocket?
I replaced my front sprocket and my adjusters are near the end. And the engine revs higher at highway speeds.
The adjusters on the CB1100 work differently than any other chain drive bike I've owned. When I first looked at my CB I also thought the adjusters were all the way out.
The adjuster bolt threads deeply into the swing arm, so instead of turning the bolt clockwise to tighten, it turns COUNTER clockwise. I bet you have plenty of adjustment left.
[Image: 01e7c7773261f0fbaf7c6f3e078d37a9.jpg]
My axle is in the exact location as yours. I guess lm ok. Can l go down on my rear sprocket?
Many of us have gone down one tooth from stock in the FRONT sprocket and had room to adjust.
  Advice on sprocket replacement? Inhouse Bob 5 564 06-24-2025, 12:57 PM
  Larger rear sprocket PowerDubs_imp 97 6,418 06-06-2018, 04:47 AM
  Chain and sprocket replacement cost ecka00_imp 2 282 03-16-2016, 07:22 AM
Last Post: Motogeezer1949_imp
