A question about wheel weights.
I'm curious now.....how many brand-new CB1100s came with balance weights on them? Mine had nothing, and neither did the 2007 BMW I purchased before that.
Also, how many of us get their wheels re-balanced about halfway through the tire life? (According to the traditional practice, you're supposed to).
As for multiple imbalanced spots, there's only one lightest spot on the tire, and that's why the companies give us that yellow dot.
Just try it for a few miles! See if you can tell a difference.
Mine had weights, front and rear.
When the factory tires were replaced at the local Honda dealer, the front took zero weights and the rear about the same as original.
with every new tire controlls my dealer the weehls.....sometimes 0-1-2-3 weights there....what cares me.....or minimum 1x in the tirelife its optimal..smile
or
if it does not help then it will not cause any damage
(11-25-2018, 04:40 AM)Retsel_imp Wrote: I just can't understand, that in this day and age with technology as it is, they still cannot design a perfectly balanced rim and tire! Seems crazy to me. Is it just laziness on the part of the manufacturer or just justification for the cost of the shop balancing equipment, charges, and training?
A casting or machined can be pretty much controlled and be balance right away, but the rubber and tyre structure is a different thing.
Technology is better, but still not perfect, and you don't need much error to make it a noticeable inbalance.
True. When I replaced the rear tire on my Triumph Bonneville, I did so just before a trip across the desert to SoCal. On the way back I had an opportunity to open it up and at 108 MPH the rear felt like I was on a pogo stick.
For riding at reasonable speeds, it was not felt, but an imbalance may lead to tire cupping.
(11-25-2018, 07:51 AM)GoldOxide_imp Wrote: Agreed. I don't think you'd be interested in a perfect $9000 rim/tire that is true/balanced only when new.
If they initiated proper quality processes, that included the goal of balance and consistency, in design, products, and production, I am confident they could produce balanced ties and rims economically. Once one manufacture started it, all would be forced to follow.
Cast rims are already well balanced, it's the tires that are reliably inconsistent, and it doesn't take much. FLYTYM said his tires were 0.5 and 0.75 oz out - that's only 15 and 21 grams each, really not very much at all. Just as a reference, I compared different valve stem and valve cap weights.
(11-25-2018, 03:27 PM)SportsterDoc_imp Wrote: Mine had weights, front and rear.
My factory wheel set had weights. It is quite possible this is something the dealer does as part of the safety certification.
(11-26-2018, 11:10 AM)pekingduck_imp Wrote: Cast rims are already well balanced, it's the tires that are reliably inconsistent, and it doesn't take much. FLYTYM said his tires were 0.5 and 0.75 oz out - that's only 15 and 21 grams each, really not very much at all. Just as a reference, I compared different valve stem and valve cap weights.
Great comparison!
I purchased my new (0 miles on the clock) 2014 CB1100 a year ago and it came out of the crate with weights on both tires.
Great comparison!
Great comparison!
Great to hear that Honda is on-the-ball.
Information Need original 2013-14 Handlebar with weights HondaLou 5 220 Yesterday, 06:16 PM
Last Post: HondaLou
  bar weights casey66_imp 9 793 06-08-2022, 10:41 PM
  Bar End Weights bvictory_imp 4 411 05-24-2021, 01:52 AM
  Friendly reminder: this bike weights A LOT franov_imp 15 1,658 04-17-2021, 02:29 PM
Last Post: Whoops
  Trailer wheel chock Buff7mm_imp 4 391 05-10-2018, 08:57 AM
Last Post: Buff7mm_imp
  Wheel exchange Gravity Storm_imp 20 1,301 09-18-2017, 12:38 PM
Last Post: Stichill
  How common are wheel & suspension upgrades? Syscrush_imp 8 664 08-09-2017, 12:22 PM
Last Post: 736cc_imp
  Handlebar end weights lash_imp 9 617 06-06-2015, 04:29 AM
Last Post: kennyw
  Front Tire Wheel Chock linuxology_imp 1 221 01-11-2015, 06:45 AM
  wheel lighting on my cb1100 jungkiwenas_imp 18 1,053 11-09-2014, 07:32 AM
Last Post: furious_blue_imp
