Fork Gaiters and Heated Grips
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 143
RE: Fork Gaiters and Heated Grips
(04-29-2025, 09:44 AM)Cormanus Wrote: I can see the pictures.
Me too
Holder of the CB1100forum Secret Decoder Ring
2012 ST1300
2013 CB1100
I find your lack of RLETs disturbing
04-29-2025, 04:27 PM
peterbaron Online
Likes Received: 597 in 327 posts
Likes Given: 1,012
Me too
me too
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
04-29-2025, 04:42 PM
Lord Popgun Offline
Virginia
Likes Given: 143
Interesting that it doesn’t switch. Looking at the diagram the rear option connector has 2 12v lines. One is R/G and the other is Bl/Br. Their source is the battery to ignition switch to the fuse block and supplies all the fuses, then out to their terminations.
The headlight shell option connector uses ground G colored wire and Bl/Br for for power. Only has 2 wires. The option connectors are on separate fuses, fuse F and G. Unless you are in the DLC connector (which has no R/G wire) the ignition OFF should remove power from the grips.
The 2010-2013 bikes are wired differently.
2012 ST1300
2013 CB1100
04-29-2025, 06:43 PM
tdbru Offline
Threads: 13
Likes Received: 40 in 22 posts
Likes Given: 11
Lord Popgun,
that's what I thought too.  I figured that plug would be on the ignition switch.  but with the key in the off position, the grips are still hot (pun intended).  So I'll just have to make sure I turn them off after using them.
-tdbru
04-29-2025, 07:53 PM
Whoops Offline
Utah, USA
Threads: 31
Likes Received: 117 in 50 posts
Likes Given: 64
(04-29-2025, 09:20 AM)tdbru Wrote: posting them directly.  Not sure why you can't see them.  they're jpeg images.  This is likely a silly question, but you have logged in, right?  Otherwise I have no idea why you can't see the images.  Perhaps follow rdprdp01's advice and free up some machine memory (clear the cache and perhaps empty the trash, clean out the temp folder) on your machine??  And if I've made a goof, please point it out so I can post pictures correctly next time.
-tdbru
I don’t think you are doing anything wrong and it wasn’t my intention to convey that. I was trying to figure out why my setup seems to be selectively omitting images, specifically in your posts. I’m very well versed in managing a computer, network and edge environment, and I’m in the range of ~85 Gb of free memory at the moment. I was only trying to determine the image host to see if my ad block rules on my DNS server are misfiring, so to speak.
04-30-2025, 06:02 AM
peterbaron Online
Likes Given: 1,012
(04-29-2025, 06:43 PM)Lord Popgun Wrote: Interesting that it doesn’t switch.  Looking at the diagram the rear option connector has 2 12v lines.  One is R/G and the other is Bl/Br.  Their source is the battery to ignition switch to the fuse block and supplies all the fuses, then out to their terminations.
I have '14-OEM heated grips.
When the ignition is off, the h/grips are disabled.
If this were my bike, I would find the line that disables the grips when the ignition is off
            *Grand Chancellor*
04-30-2025, 06:20 AM
Lord Popgun Offline
Virginia
Likes Given: 143
Is it possible the previous owner (If bought used) did some wiring mods to keep the port energized all the time? Might want to do some wire tracing…
2012 ST1300
2013 CB1100
04-30-2025, 02:24 PM
tdbru Offline
Threads: 13
Likes Given: 11
Lord Popgun,
That's a thought I hadn't considered.  I'll look.  when I traced the wires in the wiring diagram, that red/green power was ignition switched, or so it appeared to me.  the green was ground.  Perhaps the previous owner did do some switcheroos on the wires.  I'll check.  Thanks for the heads up.
-tdbru
04-30-2025, 03:18 PM
Cormanus Online
Likes Given: 1,027
I don't have heated grips, but it seems to me a really good idea to have them ignition switched.
05-01-2025, 04:21 AM
tdbru Offline
Threads: 13
Likes Given: 11
Heated grips were nice at 6AM this morning. one gets spoiled rather quickly....
-tdbru
05-02-2025, 10:50 PM
  Spare connectors/Oxford heated grips White Dog_imp 13 1,625 04-18-2025, 10:02 AM
  Fork Gaiters - buyer beware 12cb96vfr_imp 53 3,807 04-13-2025, 05:04 AM
Last Post: balkanhound_imp
  Fork Gaiters Gone in 60 15 1,308 02-13-2021, 05:12 AM
   HEATING GRIPS ICON HONDA ORIGINAL NON-OPERATING CB1100 ex 2015 EUROPE. COMPLAINT TO Alfgaxatico_imp 16 1,964 12-10-2020, 07:35 AM
Last Post: Alfgaxatico_imp
  HEATED GRIP HONDA ORIGINAL - CB1100 ex 2015 Alfgaxatico_imp 9 812 11-21-2020, 09:45 AM
  hand guards and heated grips misterprofessionality 33 2,716 11-16-2020, 10:06 AM
Last Post: mrded_imp
  thicker grips active1951_imp 15 1,298 08-04-2020, 12:55 PM
Last Post: gmike_imp
  Making closed end grips work on the CB Skypilot_imp 6 656 05-18-2019, 10:40 AM
  OEM ONLY HEATED GRIPS peterbaron 4 602 10-09-2018, 10:59 AM
   Good grips for CB1100? Which ones are you all installing? rdtshaw_imp 61 4,683 08-06-2018, 11:47 PM
Last Post: itstuantran_imp
