Oil drain plug
meowguy_imp Offline
Threads: 26
RE: Oil drain plug
Quote:Oh, and Meowguy, this could come back to haunt you about tools needed....
I stand by what I said. I changed the equation. The new drain plug was not strong enough for that much torque and I failed to pick up on that before installation.
I further believe that if you have a Honda, you use only Honda parts on the major mechanical stuff. You wouldn't think a drain plug falls in that category but it does.
Whether the "Dimple" is alloy or not I couldn't say but the red flag should have been it's size. The head on it is only 13mm, the original is 17mm and much more massive looking.
06-22-2013, 07:17 PM
Ack-CB11_imp Offline
Threads: 46
RE: Oil drain plug
Holy crap, I feel bad saying anything now. I have one in my dirtbike also, changed that one 5 times now and the CB 3 times. I've been setting the wrench for 22ft lbs.
That really stinks, I'd be pissed.
06-23-2013, 11:10 PM
Deanohh_imp Offline
Threads: 5
RE: Oil drain plug
Careful of the scale on the wrench. Some are in kg-m instead of n-m.......thats about 10x too much. Or you could be using a bad wrench that's no good in the first place. Also most torque wrenches are not accurate in the lower and upper 20% of their range.
06-24-2013, 01:34 AM
ChipBeck_imp Offline
Threads: 29
RE: Oil drain plug
(06-22-2013, 09:56 AM)HikerToo_imp Wrote: Geez, $35 bolt breaks off......I wonder if you just went by feel and not the torque wrench if you would be OK?
RE: Tools you'll need
A great thread and thanks to the ferret for giving us this.
One thing I am a stickler on is the proverbial torque wrench. You really need to include two of them in your list. You will need one that goes from from 0 to 250 inch pounds and another to take you up to at least 80 foot pounds. That's a nice looking 32mm above, but what's missing?
You just cannot do the job properly without knowing you are torqued correctly.
This is true in most areas of life!!
Chip
06-24-2013, 01:41 AM
  booster plug outback_imp 4 484 10-07-2022, 01:20 AM
Last Post: Denbow_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 675 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Gold Plug Magnetic Oil Drain Bolt 2017EX_imp 15 1,214 03-05-2020, 03:57 AM
Last Post: Teamwalker_imp
  Auxillary USB Power Plug install for IPhone Frulk_imp 22 1,289 05-12-2019, 06:00 PM
Last Post: Bazbro_imp
  Ear Plug recommendation drodg33 27 1,723 06-08-2015, 09:15 PM
Last Post: Motogeezer1949_imp
  Plug&Play Back Rest? Stealth128_imp 0 160 08-04-2014, 11:27 AM
Last Post: Stealth128_imp
  Moriwaki Swingarm Pivot Cap (Frame Plug) CB4ME_imp 17 1,135 03-06-2014, 07:38 AM
Last Post: GUNFTR_imp
  Spark plug wire colors? AllenM_imp 1 217 09-05-2013, 06:53 AM
Last Post: HondaJon_imp
