Oil drain plug
Ack-CB11_imp Offline
Threads: 46
Oil drain plug
Put one of these in during this weekends oil change, good to have and Dimple plugs are nice. We are the M14x1.5 size,
http://www.drainplugmagnets.com/hondamotorcycles.php
06-17-2013, 12:12 AM
meowguy_imp Offline
Threads: 26
RE: Oil drain plug
(06-17-2013, 12:12 AM)Ack-CB11_imp Wrote: Put one of these in during this weekends oil change, good to have and Dimple plugs are nice. We are the M14x1.5 size,
Thanks for the tip. I ordered one with my first change coming up in a week or so.
06-17-2013, 04:42 AM
meowguy_imp Offline
Threads: 26
RE: Oil drain plug
Received my drain plug today. Very fast service I must say. Looks like a very nice product, and very strong magnet. They included a total of 3 washers. Are those washers equivalent to the Honda crush washer specs. do you think?
Jim
06-20-2013, 06:54 AM
Threads: 46
RE: Oil drain plug
I used the Honda gasket, wider. Although when I did my last change the Honda washer spread out enough I had to unthread it off the plug. The same washer on the stock plug came right off??? 22 ft lbs each time, but I have a cheap torque wrench, that might have been it, those washers are soft.
06-20-2013, 07:12 AM
meowguy_imp Offline
Threads: 26
RE: Oil drain plug
(06-20-2013, 07:12 AM)Ack-CB11_imp Wrote: I used the Honda gasket, wider. Although when I did my last change the Honda washer spread out enough I had to unthread it off the plug. The same washer on the stock plug came right off??? 22 ft lbs each time, but I have a cheap torque wrench, that might have been it, those washers are soft.
Ok, thanks.
06-20-2013, 08:34 AM
meowguy_imp Offline
Threads: 26
RE: Oil drain plug
Serious bummer with my 600 mile oil change. I broke the head off the magnetic drain plug. It cannot be torqued to 25nm. I would suggest if you use this plug, no more than 15nm at the most, it is just too fragile and does not have the bulk of the original.
I SHOULD HAVE REALIZED THIS WHEN I SAW IT, SO I GUESS IT'S A BIG SHAME ON ME.Angry
They are coming to pick up the bike on Monday and take it to the shop to extract the stump. Thank God it didn't strip the crank case.
06-22-2013, 04:21 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Oil drain plug
Oh man. And the service manual says 30 Nm...
06-22-2013, 04:48 AM
HondaJon_imp Offline
Threads: 53
RE: Oil drain plug
(06-22-2013, 04:21 AM)meowguy_imp Wrote: Serious bummer with my 600 mile oil change. I broke the head off the magnetic drain plug. It cannot be torqued to 25nm. I would suggest if you use this plug, no more than 15nm at the most, it is just too fragile and does not have the bulk of the original.
Meow, was the plug made of steel or alloy? I had purchased a magnteic plug for my XR650L once and sent it back upon discovering it was alloy. Hope your ride is OK.
06-22-2013, 09:21 AM
wildezt_imp Offline
Threads: 9
RE: Oil drain plug
Thanks for sharing Meowguy...!
06-22-2013, 09:50 AM
HikerToo_imp Offline
Threads: 114
RE: Oil drain plug
Geez, $35 bolt breaks off......I wonder if you just went by feel and not the torque wrench if you would be OK?
Oh, and Meowguy, this could come back to haunt you about tools needed....
RE: Tools you'll need
A great thread and thanks to the ferret for giving us this.
One thing I am a stickler on is the proverbial torque wrench. You really need to include two of them in your list. You will need one that goes from from 0 to 250 inch pounds and another to take you up to at least 80 foot pounds. That's a nice looking 32mm above, but what's missing?
You just cannot do the job properly without knowing you are torqued correctly.
06-22-2013, 09:56 AM
  booster plug outback_imp 4 484 10-07-2022, 01:20 AM
Last Post: Denbow_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 675 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Gold Plug Magnetic Oil Drain Bolt 2017EX_imp 15 1,213 03-05-2020, 03:57 AM
Last Post: Teamwalker_imp
  Auxillary USB Power Plug install for IPhone Frulk_imp 22 1,288 05-12-2019, 06:00 PM
Last Post: Bazbro_imp
  Ear Plug recommendation drodg33 27 1,720 06-08-2015, 09:15 PM
Last Post: Motogeezer1949_imp
  Plug&Play Back Rest? Stealth128_imp 0 160 08-04-2014, 11:27 AM
Last Post: Stealth128_imp
  Moriwaki Swingarm Pivot Cap (Frame Plug) CB4ME_imp 17 1,135 03-06-2014, 07:38 AM
Last Post: GUNFTR_imp
  Spark plug wire colors? AllenM_imp 1 217 09-05-2013, 06:53 AM
Last Post: HondaJon_imp
