Oil Cooler
ChipBeck_imp Offline
Threads: 29
RE: Oil Cooler
(09-10-2013, 02:13 PM)enzo_imp Wrote: I had the same screen on a my CX650 radiator for over 8years and it never boiled.
This screen has been on the bike for 1500km, not much I know. But you can say summer has allready started here. I'll keep an eye on it and see.
Is there 2 oil lights when you turn the egnition on? One for temp?
Enzo,
I like your screen name. Have you read "The Art of Racing in the Rain"? In any event, my GT was fine with the screens for casual driving and although it ran hotter on my temp gauge it didn't overheat. But when the car was pushed with a lot of full throttle acceleration on the track the radiator with the screen on couldn't carry away enough heat and my car would red line. The 2005 GT came standard with a very coarse screen and it was eliminated by Ford in the 2006 model year to improve cooling. Here in AZ the summer temps are often above 110 degrees and cooling is a big issue for all vehicles. To get an idea of how much a screen resists airflow as speed increases, hold a framed window screen in your hand by the edge (assuming its rigid enough) out of your car window at 60 mph. If air flowed freely through it, it wouldn't have any (or much) wind resistance. But you'll find it has tremendous wind resistance as speed increases. At very low speed air passes through it but as speed increases air wants to flow around it. At very high speeds a screen is almost a solid barrier. This is why jet engine intakes are totally exposed and the engines are often damaged by pebbles sucked off of runways. A screen can't be used at all.
Chip
09-10-2013, 05:28 PM
enzo_imp Offline
Threads: 10
RE: Oil Cooler
Thanks for that info Chip, I didn't know.
09-10-2013, 07:11 PM
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 2 483 04-14-2025, 05:16 PM
Last Post: deuce17EX
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 11 1,096 04-11-2025, 02:41 PM
Last Post: rdprdp01
  Soft cooler for Djangos trip Frulk_imp 7 557 06-02-2019, 06:22 PM
  Oil Cooler Guard Chris Goldson_imp 10 982 11-09-2017, 11:41 AM
Last Post: Dvassino_imp
  EOT meter for OEM oil cooler dsinned_imp 80 5,190 12-28-2016, 09:32 AM
Last Post: HillCountryRider_imp
  Aero Bobbins and Cooler Guard Tyke57nz_imp 5 511 03-02-2014, 01:04 PM
Last Post: Tyke57nz_imp
