Honda versus Kijima rack
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
RE: Honda versus Kijima rack
That motomachines rack is pretty cute! But I'm not removing the Honda rack I have.
I want that chrome chain guard and alum. cover by the starter (not sure of the nomenclature). Guess I'm going to have to heat up a credit card!! Smile
08-08-2013, 12:17 AM
Jwayne_imp Offline
Threads: 1
(08-08-2013, 12:02 AM)Firstfour_imp Wrote:
(08-07-2013, 11:56 PM)meowguy_imp Wrote: This is the rack I am using. It is very substantial and it provides a nice little sissy bar to help keep the passenger in place.
http://www.motomachines.com/Rear-Alurack..._3313.html
How was the installation on that rack?
I have the same rack, really easy to put on. I purchased the HB 42lt top case it's a great case.
08-08-2013, 10:51 AM
Houtman_imp Offline
Threads: 115
Today I took the Kijima rack of and put the Honda OEM rack on.It was easy enough to put the Honda rack on but took a little longer than putting the Kijima rack on as that one use the original bungee bolts.With the Honda rack it is easier if you cut the short leg of a 6 mm allan wrench of to about half an inch to clear the indicator lights.Also a 12 mm 10 or 15 degree ofsett box wrench makes it a lot easier to start the rear nuts,the wrench will keep the nut in place and you can start the allan bolt by hand and than tighten with the wrench and keep it from turning with the short ,cut down allan wrench.It took me about 30 minutes to install it,a little longer than the Kijima rack.I will be selling the Kijima rack for in the for sale section .
08-09-2013, 07:02 AM
CB4ME_imp Offline
Threads: 183
More pictures, we need more pictures.Big Grin
08-09-2013, 08:36 PM
IndianRider_imp Offline
Threads: 8
[/quote]
Jwyane,
How did you install the HB topcase to the alurack ? Did you have to buy an adaptor plate ? If so, is it a HB adaptor palte or something I need to order from the manufacturer of the alurack ?
I have a Givi topcase and would like to install it on this rack with a universal givi mounting plate.
Thanks
01-28-2014, 09:22 AM
SanPete_imp Offline
Threads: 7
(01-28-2014, 09:22 AM)IndianRider_imp Wrote: I have the same rack, really easy to put on. I purchased the HB 42lt top case it's a great case.
Jwyane,
Thanks
[/quote]
Jwyane,
Thanks
[/quote]
IndianRider,
I have the same set up as Jwayne and the HB topcase and Alurack do not require an adaptor plate. The top case mounts to the rack as if they were meant for each other. I am not familiar with the Universal givi mounting plate but if you have it, here is a picture of the alurack to give you an idea if it can be installed. Hope this helps.
[url=http://s998.photobucket.com/user/sosap23/media/Alurack_zps418beb0b.jpg.html][Image: 0d86051b3a1e2d9a6ea790578624629b.jpg]
01-28-2014, 01:21 PM
  Looking for [2014] Honda luggage rack Jollygods_imp 7 833 05-09-2023, 10:30 PM
Last Post: JRM_imp
  K+H Low versus Japanese stock seat GroovyBunny86_imp 4 472 11-30-2019, 06:33 AM
  Added new Honda Travel Rack (2014 DLX) MWV1500_imp 13 986 11-24-2019, 06:31 AM
  2014 DLX - Honda luggage rack question... Barkingshins_imp 22 1,327 11-16-2019, 02:18 PM
Last Post: MWV1500_imp
  Honda Rack Install deltamark 22 1,415 04-16-2018, 12:17 AM
  Honda rear rack unsightly holes LongRanger_imp 4 457 03-05-2018, 01:56 PM
Last Post: Stichill_imp
  Kawasaki vs. Kijima Gaiters White Dog_imp 2 334 12-18-2016, 10:13 PM
  Got my Honda Rack Removed and Question postoak_imp 9 579 08-16-2016, 05:23 PM
Last Post: IndianRider_imp
  DeWalt "Tough Case" on Honda OEM Rear Rack Retsel_imp 6 518 08-14-2016, 07:41 AM
  Stock Honda Rack Frulk_imp 14 1,006 08-07-2016, 07:35 PM
