Kawasaki vs. Kijima Gaiters
White Dog_imp Offline
Threads: 59
I now have the Kawasaki OEM gaiters and offer the following comparison of measurements. In summary, the Kijima gaiters are larger, longer and looser fitting than the Kawasaki ones. The looseness of the Kijima gaiters at the bottom is a plus, as any water that gets into the gaiters will fall out much easier than the tighter-fitting Kawasaki. Stylewise, IMO the Kawasaki "look better on the CB1100 and look more "authentic to the cycle." Both of these gaiters are fully enclosed and require removing of forks to install. Plus, rubber will stretch but does not shrink.
Belllows Dia. Kawa 65mm Kijima 85mm
Gaiters Top Kawa 39mm Kijima 41mm
Gaiters Btm Kawa 59mm Kijima 65mm
Gaiters Lgth Kawa 180mm Kijima 210mm
CB1100 Fork Dia. = 41mm
CB1100 Fork Seal top dia. = 62mm
1" = 25.4mm
12-09-2016, 09:25 AM
Threads: 59
RE: Kawasaki vs. Kijima Gaiters
I spent some time this afternoon, removing the Kijima gaiters and installing the Kawasaki ones. The Kawas look sooo much better. The bottom of the gaiters are practically the same diameter of the fork seal covers so the gaiters look like they came with the cycle. The Ferret has an excellent tutorial on the "How To" section of this forum. I didn't see the torque setting for the fender bolts but I'm sure they are in the service manual. I'll check that later.
I took a look at my disc pads while I had the calipers in hand. Still have plenty of life--almost 5K miles now.
12-18-2016, 10:14 AM
Likes Given: 789
I agree, the Kawasaki gaiters just look like they belong on the bike
12-18-2016, 10:13 PM
  Fork Gaiters and Heated Grips tdbru 20 3,078 05-02-2025, 11:16 PM
  Fork Gaiters - buyer beware 12cb96vfr_imp 53 3,422 04-13-2025, 05:04 AM
Last Post: balkanhound_imp
  Fork Gaiters Gone in 60 15 1,265 02-13-2021, 05:12 AM
  ID these fork boots/ fork gaiters Riko_imp 9 836 12-18-2017, 09:43 AM
Last Post: LongRanger_imp
  New fork gaiters and plastidip under fender. Jaychaynes_imp 7 689 04-03-2017, 12:12 AM
Last Post: SSK Dave_imp
  Fork Boots (Front Gaiters) venturer434_imp 16 1,337 11-04-2016, 09:19 PM
  Triumph fork gaiters are great! Olyrider 15 1,273 03-26-2016, 05:24 PM
Last Post: TINK_imp
  Kijima Grab Bar Papa Weeley_imp 12 1,058 02-23-2016, 04:15 AM
Last Post: Papa Weeley_imp
  Fork gaiters installed - thanks Ferret! Rebel73_imp 9 1,207 01-30-2016, 01:26 AM
  MRA Vario windshield, Kijima rack & Alaskan sheepskin seat pad ScottWally_imp 15 1,014 11-18-2015, 12:41 PM
Last Post: rboe
