Black side covers
B166er_imp Offline
Threads: 15
RE: Black side covers
Clean with alcohol. Your first coat should be only about 50 percent coverage (very light dusting). Dries in 10 minutes. Go a little heavier, dry, repeat.
Red, did you tape off the emblem? I imagine no. Typically, you just peel off what you don't want dipped. Ive seen guys spray whole cars. No tape on anything. It's quicker to peel dip off windows than it is to tape off windows.
06-26-2014, 06:46 AM
Red1100_imp Offline
Threads: 5
(06-26-2014, 06:46 AM)B166er_imp Wrote: Clean with alcohol. Your first coat should be only about 50 percent coverage (very light dusting). Dries in 10 minutes. Go a little heavier, dry, repeat.
I did not tape off emblem. If I had to do it over I would put tape over emblem. It was time consuming to remove rubber. I scored the edge with razor blade. The finish came out great, no orange peel. Smooth flat black coat. No sanding, just clean with soap and water and dry thoroughly before painting.
06-26-2014, 09:57 AM
B166er_imp Offline
Threads: 15
Yeah, I'm not sure you can get orange peel. You can put the early coats on too thick which can make the whole thing sag. So to speak.
06-26-2014, 10:53 AM
  2017 CB1100EX Color matched side covers ceeko_imp 66 4,139 06-25-2023, 10:17 PM
  side covers plastic or aluminium? mrded_imp 8 648 10-03-2020, 11:33 AM
  Aftermarket Brake and Clutch Reservoir Covers michael1954 11 919 06-17-2020, 08:42 AM
Last Post: Mtneers
  Side Covers YotaMan_imp 42 2,468 05-16-2020, 08:59 PM
Last Post: Guth_imp
  Aluminium side covers for 2014 Houtman_imp 8 588 08-15-2019, 02:00 PM
Last Post: Desert viper_imp
  Installed red side covers on 2013 CB1100 Frulk_imp 15 1,173 10-05-2018, 02:54 PM
  Advice for removing emblems on side covers misterprofessionality 26 1,962 05-01-2018, 07:28 AM
  Dremeled my side covers- what do you think? PowerDubs_imp 71 3,409 02-22-2018, 03:19 AM
  Force Design air cleaner covers and side covers Bheezy27403_imp 12 916 02-19-2018, 01:44 AM
Last Post: Bheezy27403_imp
  Need help with part number for side covers jedd_imp 2 316 11-27-2017, 10:08 AM
Last Post: jedd_imp
