Where to tap speed sensor signal?
peterbaron Online
Likes Received: 573 in 311 posts
Likes Given: 954
RE: Where to tap speed sensor signal?
#91
Semi update:
Most likely it has two wire hall effect:
Hall Effect Sensor: outputs a square wave (voltages may vary depending on design)
Testing: DO NOT CHECK SENSOR RESISTANCE as this may damage it, due to the circuitry used in the sensor.
...unlikely
Permanent magnet, induction type sensor: This type creates an analog signal. You can check sensor resistance if you have the specification, and you won’t damage it.
Bottom line: need a scope, as popgun and others said.
I tried to go through the back door but
".. the Honda Tech dept couldn’t give us an answer.."
More will come after vacation.
08-15-2018, 08:34 AM
peterbaron Online
Likes Given: 954
#92
No update so far = no scope, sorry
10-19-2018, 08:29 AM
Lord Popgun Online
El Supremo RLET Force
Virginia
Likes Given: 136
#93
I tried using my scope on the wires with a cheap clamp on current sensor probe and got no good results. I now have a Tectronix current probe. But I forgot about this. Maybe I’ll try again tomorrow and see what I come up with.
If no results, I might make a test harness that will allow me to use a regular probe directly on a wire. I don’t want to stab the wires, thus a test harness.
10-19-2018, 08:41 AM
peterbaron Online
Likes Given: 954
#94
Thumbs Up thanks popgunSmile
Let us know, so PowerDubs-Josh can finish his project...
10-19-2018, 08:49 AM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,035 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Turn Signal Indicators balkanhound_imp 5 642 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,448 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Negotiator-S Speed Pulse Modulator? TonyJames_imp 18 1,750 11-14-2022, 04:50 PM
Last Post: rich_imp
  Can someone with a power commander on a 6-speed bike check something for me? PowerDubs_imp 10 788 05-15-2022, 11:42 AM
  auto tune 02 sensor outback_imp 18 1,344 03-16-2022, 07:48 AM
Last Post: outback_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 2,390 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 695 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Turn Signal Relocation Cormanus 11 817 12-30-2020, 11:12 AM
  Signal Relocation Ben70_imp 7 722 02-20-2020, 10:22 AM
Last Post: Ben70_imp
