Yamaha Niken
#91
Not in any order
• Front end ride “over bumps” is the biggest advantage of this design. Yet few of the test mention this?
• Turning radius is very tight/small. This is a huge advantage for me out here with all the dead ends here. Narrow 2 lane roads are all zero-point U-turns for the Niken. The R9T was at least a 3 point turn every time. Stop when you hit the ocean. Equally noticeable as the smooth ride with little mention online.
• Brakes are a little weak but it will still do a stoppie, I’ve seen.
• Yamaha did a few other thing to help deal with this mass, heavier crank shaft, steel 1st 2nd and 3rd trans gears.
• Mirrors excellent view
• Top heavy when stopped 580lbs ride ready. Roughly 100lbs over the Tracer GT “2 wheeled counterpart” but 40lbs of it is right behind the headlight. CB is 540
• Counter steering is effortless compared to one wheel
• Absolute minimum handle bar vibes
• Tall seat height 32.9” CB = 30.5”
• Cost saving side bags non-water proof
• Cruise control
• Heated grips
• Stock seat on GT is well padded and comfy
• Sport seat is ½“ lower, less padded. Fine for island riding
• GT windscreen is tall but non-adjustable
• Straight up seating position Forward lean 0° CB’s are 11°
251* miles so far
* = all within 50 sq miles
This bike reminds me I haven’t owned a water cooled bike since 2004 a 98 Kawasaki KSR-80 which is a Grom sized bike, 80cc 2-stroke.
ACK
Sounding good so far, Ack, although this vertically challenged Aussie would not like the extra 2" of height.
(11-05-2019, 10:26 AM)Cormanus_imp Wrote: Sounding good so far, Ack, although this vertically challenged Aussie would not like the extra 2" of height.
Cormanus: You just need never to stop. That is a rider's wet dream!
But if you must, just ride in a tight circle. Smile
ROFL
you get too a Lowering kit for the niken.....ok you lose lean angle
For the Niken Yamaha makes a 12mm lowering bushing for the rear and slide forks to match.
I've had taller:
06 BMW HP-2 39" seat at 410 lbs all in. This was one of my favorites, only 225 in the US. I dropped this one 6 or 8 times at stops and gas stations......VERY embarrassing. This has been the only bike I actually rode somewhere, did a trip to Virginia Int Raceway for a AMA race weekend. 12,000 bikes, 1 HP-2. 10 hrs of all rain for the return.
The Niken has an extra 170 lbs and is a lot worse at a dead stop. Maybe some crash bars are in my future?
ACK
geezalou 39" seat height would be near my armpit lol
I must have spoke too soon about the crash bars!!
I was ready to roll out the door and put up the kickstand before throwing my leg over, that was my mistake. The freshly buffed floors are really slippery, left leg slowly slid out from under me and down we went. I was able to set it down easy as my leg slid sideways. No groin pull Big Grin. Bike looks even stranger on it's side?
Damage: none really
The real kicker was I couldn't lift the beast back up. I'd lift it up but the lower tire couldn't grip the floor enough and just kept sliding away. It was heavy and I had a hard time lifting it. Luckily a co-worker came in after 30 min and 4 attempts and almost a 2nd coranery, we hauled her up.
Not a drop of anything leaked out and the tank was even full, the BMW would have been a mess.
I want to make sure it was all the floor fault so I'm planning to lay a blanket down outside and try it in a natural setting, with a helper. If I can't lift this thing I'll have to start a workout plan Sad
Feeling weak, ACK
Bummer, Ack. I’m glad you escaped the coronary!
wow !! .. what a shocking pic.. bikes always look so helpless when they are laying over like that.. you want to pick it up quickly and give it a comforting hug, like it were your child..
  2024 Yamaha XSR900 GP: Born Iconic PowerDubs_imp 11 987 11-03-2023, 02:50 AM
  2018 Yamaha Bolt r-spec SportsterDoc 22 1,541 12-19-2022, 06:13 PM
  2023 Yamaha XSR900 Gone in 60 2 361 11-19-2022, 02:33 AM
Last Post: bioman_imp
  Yamaha XSR700 motoWest_imp 4 447 05-20-2021, 11:44 PM
Last Post: michael1954
  another Yamaha in the family the Ferret 12 759 06-29-2020, 02:21 PM
Last Post: IndianRider_imp
  Yamaha Tracer 4 Paws_imp 2 297 06-25-2020, 04:24 PM
Last Post: zirconxi_imp
  Yamaha SRX 250 Project Tezza_imp 7 515 03-06-2020, 06:40 AM
Last Post: bflint
  2015 Yamaha SR 400 redbirds_imp 37 2,228 01-12-2020, 03:33 AM
Last Post: E11even_Hunnit
  niken alprider 14 998 10-26-2019, 09:54 AM
  Niken's Little Brother Ack-CB11_imp 3 358 10-25-2019, 08:47 AM
