Larger rear sprocket
#91
(04-18-2018, 02:57 AM)Retsel_imp Wrote: Alain, here is the front sprocket from Sunstar.
http://sprocketcenter.com/street-sprocke...ocket.html
I was out on the freeway yesterday and found that I am now, with 42 tooth rear sprocket, turning 3500 rpm at 70 mph in 6th. 65, my crusing speed, was at 3200 rpm. Works for me!
Using the chart provided by PD, it is pretty close at 3401 for a 70 mph speed. With the 42 tooth.
Thanks will get both (Fr & Rr) in a few days
(04-22-2018, 04:12 AM)PowerDubs_imp Wrote: Installed
[Image: 3ecc8215667999aa13fa564ab8058874.jpg]
The sliver, unpainted, sprocket looks good. Can't wait to see what you think of the change.
Can any one can confirm the number of tooth for the Drive front sprocket.
I already got the part number for the rear sprocket for 42 tooth..
Bike is a 2017 CB1100
Thanks.
I think it's 18T. See https://www.partsfish.com/oemparts/a/hon...nsmission.
Looks like the rear is 40T https://www.partsfish.com/oemparts/a/hon...r-wheel-1, but you may be looking for a larger one.
(05-15-2018, 03:08 AM)Alain Lee_imp Wrote: Can any one can confirm the number of tooth for the Drive front sprocket.
Thanks.
It's 18 teeth
Thanks all for the info
Is the increased torque enough to lift the front wheel off the line?
Much easier than before, yes.
  Advice on sprocket replacement? Inhouse Bob 5 581 06-24-2025, 12:57 PM
  Going up 1 on the front sprocket DBM_imp 17 1,430 08-21-2018, 08:36 AM
Last Post: riggies_imp
  Chain and sprocket replacement cost ecka00_imp 2 289 03-16-2016, 07:22 AM
Last Post: Motogeezer1949_imp
  larger tanks on the '14s. Olyrider 1 233 05-12-2015, 05:52 AM
