Had to add gaiters!!
Ridem32_imp Offline
Threads: 51
#91
I use my phone and use tapatalk it's a free app. I'm on tapatalk now and can send pic from my phone it's so easy
Michael
04-27-2014, 05:06 PM
Likes Given: 1,028
RE: Had to add gaiters!!
#92
(04-27-2014, 05:06 PM)Ridem32_imp Wrote: I use my phone and use tapatalk it's a free app. I'm on tapatalk now and can send pic from my phone it's so easy
Michael
Yep. That's another good solution.
04-27-2014, 05:08 PM
ss2wheels_imp Offline
Threads: 40
#93
My kaw gaiters came in today, when I am feeling like some back pain I will install them.Can someone give me torque specs for axle, tree bolts and caliper bolts please.Huh thanks fellas..
04-28-2014, 05:36 AM
Likes Given: 806
#94
Axle nut r/ h side 44 ft lbs
Caliper bolts 23 ft lbs
Axle pinch bolts 19 ft lbs
Bottom tree pinch bolts 32 ft lbs
Top bridge bolts 17 ft lbs
04-28-2014, 06:43 AM
Threads: 40
#95
(04-28-2014, 06:43 AM)The ferret_imp Wrote: Axle nut r/ h side 44 ft lbs
Thanks buddy, I knew you could help me out! You da manBeer
04-28-2014, 06:49 AM
Ridem32_imp Offline
Threads: 51
#96
SS2wheels no back pain the fork tubes just drop out. Good hour and your done. Need any help let me know
Michael
04-28-2014, 06:50 AM
Threads: 40
#97
(04-28-2014, 06:50 AM)Ridem32_imp Wrote: SS2wheels no back pain the fork tubes just drop out. Good hour and your done. Need any help let me know
Michael
Thanks for the offer mike, I do all the work that I can on my bikes cause I know I will do a better cleaner job than 90% of the so called techs out there but 35 years as an auto painter has got me a trick back!
04-28-2014, 07:22 AM
Ridem32_imp Offline
Threads: 51
#98
SS: nothing is heavy. Put a floor jack with a. 1 x6 under the motor jack just enough to get back tire on the ground, front off the ground. Then remove fender then forks ready to slide out after removing the brake claipers. Take your time. What I meant by help was your welcome to call me and I can walk you thru the steps the easy way. Took me a hour could do a set of gaiters now less than 40 min you will like them once you get them on Wink
Michael
04-28-2014, 09:53 AM
Threads: 40
#99
Hey mike looks like you leave the abs sensor bracket on the rt fork leg, best way do it?
04-29-2014, 08:52 AM
12cb96vfr_imp Offline
Threads: 27
sorry boys been busy, here are some finished product pics....pulled the reflectors and added the gaiters. couple zip ties and some tire glue did the trick, cutting them was a piece of cake! not sure how durable they will be, but im happy for now Smile
uploading some close ups now
04-29-2014, 09:47 AM
  Fork Gaiters and Heated Grips tdbru 20 3,216 05-02-2025, 11:16 PM
  Fork Gaiters - buyer beware 12cb96vfr_imp 53 3,882 04-13-2025, 05:04 AM
Last Post: balkanhound_imp
  Fork Gaiters Gone in 60 15 1,316 02-13-2021, 05:12 AM
  ID these fork boots/ fork gaiters Riko_imp 9 879 12-18-2017, 09:43 AM
Last Post: LongRanger_imp
  New fork gaiters and plastidip under fender. Jaychaynes_imp 7 706 04-03-2017, 12:12 AM
Last Post: SSK Dave_imp
  Kawasaki vs. Kijima Gaiters White Dog_imp 2 359 12-18-2016, 10:13 PM
  Fork Boots (Front Gaiters) venturer434_imp 16 1,422 11-04-2016, 09:19 PM
  Triumph fork gaiters are great! Olyrider 15 1,350 03-26-2016, 05:24 PM
Last Post: TINK_imp
  Fork gaiters installed - thanks Ferret! Rebel73_imp 9 1,212 01-30-2016, 01:26 AM
  Gaiters for my CB Grinton_imp 6 592 05-08-2015, 05:45 PM
Last Post: TINK_imp
