Design Problem, Rear Wheel shifting to left - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: General Discussion (https://cb1100forum.net/forum/forumdisplay.php?fid=6) +--- Thread: Design Problem, Rear Wheel shifting to left (/showthread.php?tid=2676) |
RE: Design Problem, Rear Wheel shifting to left - ChipBeck_imp - 12-06-2015 (12-06-2015, 04:43 AM)LongRanger_imp Wrote:(12-05-2015, 02:03 PM)ChipBeck_imp Wrote:(12-05-2015, 03:05 AM)LongRanger_imp Wrote: Oh heavens, you posted a photo of your license plate on the internet? Long, 7.5 gallons is iron butt capacity for sure. I've been a helicopter pilot for the last 30 years and the Long Ranger is a stretch version of the Bell 206 Jet Ranger helicopter. I had never heard that name used for anything else. You are right though, it fits. Chip RE: Design Problem, Rear Wheel shifting to left - emptysea - 12-08-2015 Don't know if this would help the gentleman with the off-center tire, but I found this to be a fairly interesting "how to" -- [url=http://www.cycleworld.com/2015/12/08/ienatsch-tuesday-how-to-use-string-for-motorcycle-wheel-alignment/?src=SOC&dom=fb]Cycle World "How To 'String' A Motorcycle (corrected because Cormanus is a nerd)" RE: Design Problem, Rear Wheel shifting to left - Pterodactyl_imp - 12-08-2015 MTC, that article brings into play other causes for a tyre appearing to be off centre. A chain adjustment gone wrong or a bent frame for example. String alignments were common on cars in the good old bad old days and some people still do them at home. Without toe in and camber to complicate matters, a string alignment on a motorcycle is a straightforward way of checking that a chain adjustment has been carried out correctly. It's not an exact science but if a string alignment check was way out it would be cause for further investigation. Thanks for posting. Cheers RE: Design Problem, Rear Wheel shifting to left - Cormanus - 12-09-2015 (12-08-2015, 03:57 AM)EmptySea_imp Wrote: Don't know if this would help the gentleman with the off-center tire, but I found this to be a fairly interesting "how to" -- OK, MTC, I give up. How do you sting a motorcycle? RE: Design Problem, Rear Wheel shifting to left - jmc1100_imp - 12-09-2015 You all have good eyes. I can't see past that big blacked out plate.. RE: Design Problem, Rear Wheel shifting to left - emptysea - 12-10-2015 (12-09-2015, 05:53 AM)Cormanus_imp Wrote:(12-08-2015, 03:57 AM)EmptySea_imp Wrote: Don't know if this would help the gentleman with the off-center tire, but I found this to be a fairly interesting "how to" -- OK, MTC, I give up. How do you sting a motorcycle? Picky Picky Picky |
