Front wheel bearings shifted in hub. - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Front wheel bearings shifted in hub. (/showthread.php?tid=5383) |
RE: Front wheel bearings shifted in hub. - pekingduck - 05-30-2017 I think you have latched onto this floating bearing theory and are not open to any other possibilities. Good luck. RE: Front wheel bearings shifted in hub. - Searcher_imp - 05-31-2017 (05-30-2017, 10:13 PM)pekingduck_imp Wrote: I think you have latched onto this floating bearing theory and are not open to any other possibilities. Good luck. Thanks. RE: Front wheel bearings shifted in hub. - Searcher_imp - 06-04-2017 (05-30-2017, 08:04 PM)Aka Tsubasa_imp Wrote: I have a hard time believing caliper bolts moved a hub bearing. Especially since tightening a caliper would cock the wheel. Bearings usually need an even application of force to move. Something very simple is being missed here. What he said. Something had to move when I tightened the left caliper bolts with the wheel shifted to the right of center by reason of the axle spacers installed backwards. It was the brake pads, which got pushed over to one side of the caliper (pistons on one side fully extended). Then when I installed the spacers correctly and slipped the left caliper over the disk the caliper hit the fork because it was cocked. All I had to do was twist the caliper to recenter the pads in it and the caliper slipped right on inside the fork as it was supposed to. Duh!!! RE: Front wheel bearings shifted in hub. - Cormanus - 06-04-2017 Well that's good news, Searcher. All OK now? RE: Front wheel bearings shifted in hub. - Searcher_imp - 06-04-2017 (06-04-2017, 12:59 PM)Cormanus_imp Wrote: Well that's good news, Searcher. All OK now? I'm back on the road. Thanks. RE: Front wheel bearings shifted in hub. - the Ferret - 06-04-2017 Great, glad nothing was too remiss and you were able to get it sorted and back on the road. RE: Front wheel bearings shifted in hub. - Rocky_imp - 06-05-2017 Good to hear that you sorted it out. I was following this thread and for the life of me I couldn't understand why it wouldn't go back together. Sometimes it's the silliest things that drive you nuts. RE: Front wheel bearings shifted in hub. - cb4me?_imp - 06-10-2017 (06-05-2017, 09:22 AM)Rocky_imp Wrote: Good to hear that you sorted it out. Me too. Good to see the happy ending! |
