New tires! - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: New tires! (/showthread.php?tid=4138) |
RE: New tires! - Davidjill_imp - 10-07-2024 Ah thanks. I have found Bridgestone T32’s in stock size and available near me RE: New tires! - Tev62 - 10-07-2024 (10-07-2024, 05:33 PM)Wisedrum_imp Wrote: After a few Bridgestone BT54F for the front I changed to BTO23 in stocksize. Hopefully I will get more km out of this tire than out of the previously used ones, which lasted round about 13.000km averagely. I guess I will, because the BTO23 has a totally different profil structure. I like the BT023 as a tyre, a good all rounder which has been around for a while. I'm currently at 9,600km on a pair of these on my Daytona 1200 which is a little lighter than the CB1100EX (to my surprise). I reckon the front will go to around 12K km to get to the wear indicator. I wouldn't be heavy on the brakes either. You don't have a choice on the Daytona anyway, they are rubbish! The rear oddly has a bit more meat on it but is a bit squared off affecting handling which would prompt me to change prematurely.
RE: New tires! - Wisedrum - 10-09-2024 A picture of BT023 showing the Profil structure. RE: New tires! - michael1954 - 10-09-2024 (10-09-2024, 03:27 PM)Wisedrum_imp Wrote: A picture of BT023 showing the Profil structure. Interesting profile, almost looks backwards. How do these tend to wear and handle? RE: New tires! - Wisedrum - 10-10-2024 When I look at the picture I also notice that the tire seems to be mounted backwards. While riding the CB I do not notice something unusual. The bike behaves the same as ridden with BT54F. I will check out the arrow on the tire, it should show in the right direction. The tire was mounted by a motorbike mechanic, so it should be the case. If not, I will tell him and he has to redo his work. RE: New tires! - Wisedrum - 10-10-2024 No need to worry. After checking out the arrows on the front and rear tire, everything is right. The mechanic mounted the front tire correctly. Both point in the same forward rotating direction. I still wonder about the front profile but it should be this way. So what! First picture shows the front tire and second the rear tire. RE: New tires! - michael1954 - 10-11-2024 (10-10-2024, 04:28 PM)Wisedrum_imp Wrote: No need to worry. After checking out the arrows on the front and rear tire, everything is right. The mechanic mounted the front tire correctly. Both point in the same forward rotating direction. I still wonder about the front profile but it should be this way. So what! |
