Threads: 18
Likes Given: 2
I am going to be an optimist  and believe I will be able to ride this fall and winter, regardless of my problems with my vision. So, I am finally putting new tires on my EX. I remember reading several threads about increasing the tire size, but my memory failed me. I went ahead and ordered std size, front and rear, new radial-ply tubes and rim flaps for both tires. I hope I did not buy a 'bad' tires without the Forum's advice, but I bought Bridgestone's BT54 tires all around. The std size has served me well, even though I do like the look of a larger tire, the bike has never seemed to need them. Hopefully I did okay. I am glad to be back! Thanks, George, for the trick to get the Forum looking like it used to!
Likes Received: 512 in 234 posts
Likes Given: 676
Michael for most of us I think, going to larger sizes was not because of a fault with the stock tire sizes, but due to a lack off alternate replacements available in the stock sizes.
Threads: 18
Likes Given: 2
(08-27-2024, 12:11 PM)The ferret_imp Wrote: Michael for most of us I think, going to larger sizes was not because of a fault with the stock tire sizes, but due to a lack off alternate replacements available in the stock sizes. Know much about the BT54 tires? They replace the D205's, which I could not find, and are std size radials.
Threads: 344
Likes Received: 761 in 421 posts
Likes Given: 893
The only reported problem I recall with the BT54s is that the front tyre doesn’t last too long. Can’t say myself; I’ve never had them, but forum members have had them.
Bridgestone’s BT32s get a better wrap.
Threads: 9
Likes Received: 56 in 16 posts
Likes Given: 2
(08-27-2024, 02:51 PM)Cormanus_imp Wrote: The only reported problem I recall with the BT54s is that the front tyre doesn’t last too long. Can’t say myself; I’ve never had them, but forum members have had them.
That's right with the BT54. Only half as long as the rear tire. In numbers, 15.000km compared to 30.000km. Now I mounted the BT023 as a front tire and hope for more km. It has a very different deeper profile structure and is available for the CB. Will see how it works out. In Germany we are alllowed to mix tires as long as the fitting specs are right. They are.
Threads: 18
Likes Given: 2
(08-27-2024, 04:39 PM)Wisedrum_imp Wrote: (08-27-2024, 02:51 PM)Cormanus_imp Wrote: The only reported problem I recall with the BT54s is that the front tyre doesn’t last too long. Can’t say myself; I’ve never had them, but forum members have had them.
Since it seems I bought a front that will not last too long, it seems it must be softer rubber. Did it grip better since softer tires usually do?
Threads: 18
Likes Given: 2
(08-28-2024, 01:16 AM)m in sc_imp Wrote: not really. tread depth was fairly dismal from new Funny, I googled the BT54 tires and found a thread from the Forum from 2014. Several members were thrilled about the tire and its performance. Not sure if they are still here or if they kept using them, but at the time they seemed to like them. Guess I will find out since they will be here Tuesday next week.
Threads: 18
Likes Given: 2
Likes Given: 676
Michael, do you have a tread depth gauge?
Threads: 18
Likes Given: 2
(10-01-2024, 05:59 AM)The ferret_imp Wrote: Michael, do you have a tread depth gauge?
No, but just eyeballing it, the T-32 looked way deeper than the front BT54. I wonder if it even had 2/32 of an inch. It looked way shallow compared to the T-32. I sent it back, so I do not know its true depth, but I have seen enough tires to know it looked funny.
(10-01-2024, 04:06 AM)michael1954_imp Wrote: ![[Image: 488e957d00e640c76b11e0c490c19f57.jpg]](https://cb1100forum.net/forum/uploads/imp/202410/488e957d00e640c76b11e0c490c19f57.jpg)
![[Image: 2b08a33a369505ce2600a766d848206e.jpg]](https://cb1100forum.net/forum/uploads/imp/202410/2b08a33a369505ce2600a766d848206e.jpg)
![[Image: 491c2da5b46e12052e6d6dd6928cc4b1.jpg]](https://cb1100forum.net/forum/uploads/imp/202410/491c2da5b46e12052e6d6dd6928cc4b1.jpg)
![[Image: da55850128c5ea83ca2b58c7d895ce32.jpg]](https://cb1100forum.net/forum/uploads/imp/202410/da55850128c5ea83ca2b58c7d895ce32.jpg)
Hi guys, these are the pixs of the BT54s I bought new. The picture that shows both in the box, shows how bad the front looks. I also have a pix of the new rear BT54 and the new T-32. What do you all think? I am glad I returned the front BT54, as it looked used and with very thin thread. The T-32 looks much deeper and should last much longer. The third pix is the front BT54.
![[Image: 377dce8f35c603b156a542abcb95732b.jpg]](https://cb1100forum.net/forum/uploads/imp/202410/377dce8f35c603b156a542abcb95732b.jpg)
This last pix is the new T-32. Another pix of the T-32 showed up, the front BT54 is the 4th pix.
