Motor cuts off - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Motor cuts off (/showthread.php?tid=5964) |
RE: Motor cuts off - The Spaceman_imp - 06-06-2014 (06-06-2014, 10:13 PM)JohnNevets_imp Wrote: Didn't he say he had disconnected that switch? Hey, let's not start reading the posts before we reply to them. We have standards here. RE: Motor cuts off - Guth_imp - 06-07-2014 (06-06-2014, 11:31 PM)The Spaceman_imp Wrote:(06-06-2014, 10:13 PM)JohnNevets_imp Wrote: Didn't he say he had disconnected that switch? For a second, I was thinking that you were talking about rules of behavior. Then I realized you simply meant standards as in motorcycles and the CB1100 in particular. By the way, for the OP, the battery terminal suggestion is a good one. Also, did you check to verify that the sidestand switch functionality was disabled when disconnecting? RE: Motor cuts off - Ole - 06-07-2014 In my dirt riding days, those gol darned side stand switches got disabled in a hurry. The way you described your symptoms, that would be the first place I would look. RE: Motor cuts off - wayne van horn_imp - 06-07-2014 stop going over railroad tracks, end of problem. RE: Motor cuts off - dBuster_imp - 06-07-2014 Wouldn't disconnecting the site stand switch, which was mentioned in the first post, be the same as disabling it? Or is there more to it? Sent from my XT1055 using Tapatalk RE: Motor cuts off - Ace miller_imp - 06-07-2014 Thanks for all the suggestions.......it is still under warranty so it off to the shop next Wednesday. Just wondered if anyone had experienced the same problem. I've been riding for 55 years so I've checked all the obvious causes! RE: Motor cuts off - Tortuga_imp - 06-07-2014 (06-07-2014, 12:01 AM)Guth_imp Wrote:(06-06-2014, 11:31 PM)The Spaceman_imp Wrote:(06-06-2014, 10:13 PM)JohnNevets_imp Wrote: Didn't he say he had disconnected that switch? For a second, I was thinking that you were talking about rules of behavior. Then I realized you simply meant standards as in motorcycles and the CB1100 in particular. Your first guess was right, he was deploying a sarcasm bomb. RE: Motor cuts off - Red Mist_imp - 06-07-2014 (06-07-2014, 06:08 AM)dBuster_imp Wrote: Wouldn't disconnecting the site stand switch, which was mentioned in the first post, be the same as disabling it? Or is there more to it?Yessir, you dont wanta jest disconnect it you need to jumper it so its always closed. Closed means it makes contact. Continuity. VOM used for this. Anyway im sure this post is super flew us becuz ya'll serely gots it figured out without any input from dumb ole redmist ![]() ![]() ![]() ![]() ![]() (06-06-2014, 08:11 PM)Tortuga_imp Wrote:(06-06-2014, 06:20 PM)ingobohn_imp Wrote: Maybe the sidestand's spring is a bit weak or loose or lengthened that in case of crossing any bump the sidestand moves down a little bit and kills the engine (security switch if side stand is used while engine is not in N). You saved me typing it. This will most likely be what's occurring. Try taping the stand in the fully up position and jumping over some hump back bridges. Oh and make a video of it! oh you got to be kidding me. why not just take the bike in and have em run a ct scan, er, that is, a ecu scan. also clutch switch could be the cause also dont this bike have a tipover cutout maybe thats it guess i been hanging around Breck too much and drinking about a gallon of beer
RE: Motor cuts off - Obliviontoad - 06-07-2014 Wait, no tip over switch? I just assumed. My Shadow RS was recalled for a faulty one that did this exact same thing. Guess I learned sumthin. Motor cuts off - Ridem32_imp - 06-07-2014 Does it do it at any big bump? Or just the same train track? We had a car back in the. 80, s that a woman said everytime she drove across the same train track her car would die then crank rite back up! We thought she was crazy ! Lol. We drove her car to that train track and yes it would go dead!! The ECM was picking up a signal from the train track control box that controlled the arms that drop down. We wrapped her ECM with aluminum foil and it fixed it. Weird but true. If it happens over any big bump it's the kickstand switch or weak spring. Put on center stand put in first gear and just wiggle the side stand by hand if it dies you know it's weak spring or bad switch. Let us know |
