83lbf-ft on the rear axle nut - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: 83lbf-ft on the rear axle nut (/showthread.php?tid=5885) |
RE: 83lbf-ft on the rear axle nut - mininsx_imp - 11-12-2014 When I was a VW mechanic we used to joke about tightening bolts with this: "Strip the threads then back it off a half a turn." RE: 83lbf-ft on the rear axle nut - Houtman_imp - 11-12-2014 (11-12-2014, 01:54 AM)mininsx_imp Wrote: When I was a VW mechanic we used to joke about tightening bolts with this: "Strip the threads then back it off a half a turn."That is funny ! RE: 83lbf-ft on the rear axle nut - Deanohh_imp - 11-12-2014 Wouldn't hurt to get your torque wrench checked at the value your target value. None of them stay accurate forever. You're not going to bend the swing arm, but you could start to collapse the bearing spacer which would really screw up your bearing alignment, causing the inner to outer race alignment to be tight and squeeze the grease out of the contact surfaces, overheat, and destroy the bearings. RE: 83lbf-ft on the rear axle nut - Razorbacjac_imp - 11-12-2014 (11-12-2014, 05:41 AM)Deanohh_imp Wrote: Wouldn't hurt to get your torque wrench checked at the value your target value. None of them stay accurate forever. You're not going to bend the swing arm, but you could start to collapse the bearing spacer which would really screw up your bearing alignment, causing the inner to outer race alignment to be tight and squeeze the grease out of the contact surfaces, overheat, and destroy the bearings. I'll have to remember that. Sounds like good advice. RE: 83lbf-ft on the rear axle nut - Houtman_imp - 11-12-2014 Once a year I check my clicker style torque wrench against a beam type to make certain that the settings are spot on. A beam type does not loose its accuracy much and I use the beam type only to check the clicker wrench. RE: 83lbf-ft on the rear axle nut - CBenthuzed_imp - 12-19-2014 I am awaiting my service manual. I have read on this forum that the axel bolt and nut required a 27mm and 32 mm. That is not what I have on my 2014 CB 1100 Deluxe. The bolt head on left is 22 mm and the nut on right is 27mm or SAE 1 1/16th inch. I did do the chain adjustment which was needed due to chain slack at 601 miles and first service. Was difinitly getting chain clunking on acceleration. Does anyone have the correct Honda torque spec for the rear axel nut on the 2014 Honda CB 1100 Deluxe model. I believe someone had posted 68 ft. lbs. but not for sure its for the 2014 C1100 Deluxe. Seems there must be a least 2 differant axels for these CB 1100. Any help is appreciated.
RE: 83lbf-ft on the rear axle nut - the Ferret - 12-19-2014 65 ft lbs see post 1 about 1/2 way down http://www.cb1100forum.com/forum/showthread.php?tid=2708 RE: 83lbf-ft on the rear axle nut - CBenthuzed_imp - 12-19-2014 Thanks so much Ferret. Been waiting all day for USPS to bring the service manual. No show yet. I will have to read through your thread on the 600 mile service as I hadn't seen it until your response and the link to it. Thanks again for the help and hope to return the favor. I do like turning me own wrenches.
RE: 83lbf-ft on the rear axle nut - dave - 12-19-2014 You won't bend the swing arm because there is a spacer between the wheel bearings preventing this from happening, but you could strip the threads on the nut. If the spacer wasn't there you would destroy your wheel bearings first - they're not designed for that kind of load. RE: 83lbf-ft on the rear axle nut - CBenthuzed_imp - 12-19-2014 (12-19-2014, 01:08 PM)Dave_imp Wrote: You won't bend the swing arm because there is a spacer between the wheel bearings preventing this from happening, but you could strip the threads on the nut. If the spacer wasn't there you would destroy your wheel bearings first - they're not designed for that kind of load. Thanks Dave, I had previously torqued the axle nut to 68 ft.lbs on my 2014 CB 1100 Deluxe, as I had earlier read in the forum that it was either 68 or 85 ft. lbs, but wasn't sure which torque was for which axle as there seems to be two differant axles for these CB 1100's. Per Ferrets response, I re-torqued the axle nut to 65 ft. lbs. I'm assuming that 3 ft.lbs over didn't do any damage since I didn't ride the bike. So I think were good. Thanks again!
