What are some (uncommon) maintenance tips that not many people know about? - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: What are some (uncommon) maintenance tips that not many people know about? (/showthread.php?tid=5709) |
RE: What are some (uncommon) maintenance tips that not many people know about? - Wisedrum - 09-05-2015 (09-04-2015, 01:15 PM)jeffskar_imp Wrote: I have one very firm belief on something that takes a huge toll on many, many vehicles/motorcycles. In my opinion this is pretty too short, to warm the CB engine really up for giving it full throttle. After 5 minutes it only remembers, that it should work now, but somehow is still half asleep. Wisedrum RE: What are some (uncommon) maintenance tips that not many people know about? - furious_blue_imp - 09-05-2015 (09-05-2015, 02:17 AM)Wisedrum_imp Wrote:(09-04-2015, 01:15 PM)jeffskar_imp Wrote: I have one very firm belief on something that takes a huge toll on many, many vehicles/motorcycles. In my opinion this is pretty too short, to warm the CB engine really up for giving it full throttle. After 5 minutes it only remembers, that it should work now, but somehow is still half asleep. Wisedrum +1000 on this very good advice: don't rev up a cold engine. I had a neighbor once that would habitually start and then rev up her CB350, wah wah wah wah... followed by a full throttle take off within 5 seconds of being started. With less than 10k miles on it, her bike wore out a small end bushing, you cold hear the loud knocking from the loose piston.. The bike got a very early top end rebuild because of the cold revving habit. The ball bearing parts could probably take the abuse, but not the plain bushing on the rod's piston pin side. Oil starved bearings don't like being leaned on.. RE: What are some (uncommon) maintenance tips that not many people know about? - Toro5xi_imp - 09-05-2015 I second the changing of brake and clutch fluid. I try to do it on all my cars and motorcycles every 2 years regardless of miles. Brake fluid is hydroscopic and really gets nasty. I bought a vacuum pump several years ago which hooks up to the bleeder screw and makes it a simple one person job. Simply fill up the fluid reservoir and crack the bleeder screw and let the vacuum pull the fluid though. One item I have been very lax on is the swing arm bolt which attaches the swing arm to the frame. I am rebuilding a 1993 ZX7 and had to make a drift on the lathe the exact OD size of the bolt to drive it out of the frame and swing arm. It had rusted so tightly to the swing arm bearings I was using a really large hammer to get it out. I had heard some horror stories what could happen if this bolt was not removed and greased occasionally but never had one this bad. RE: What are some (uncommon) maintenance tips that not many people know about? - dave - 09-06-2015 That's a top tip Dave and I might add using the high pressure air to dry and clean the chain after using chain cleaner, then apply your favorite chain lube. [/quote] Hi Redbirds, I do that also. I use WD40 to clean my chain; do you purchase specific chain cleaner? RE: What are some (uncommon) maintenance tips that not many people know about? - redbirds_imp - 09-06-2015 (09-06-2015, 01:15 AM)Dave_imp Wrote: That's a top tip Dave and I might add using the high pressure air to dry and clean the chain after using chain cleaner, then apply your favorite chain lube. Hi Redbirds, I do that also. I use WD40 to clean my chain; do you purchase specific chain cleaner? [/quote] Hi Redbirds, I do that also. I use WD40 to clean my chain; do you purchase specific chain cleaner? [/quote] I have in the past but WD-40 is what I use now, cheaper and gets it done. I also use a soft bristle tooth brush to get in the links. RE: What are some (uncommon) maintenance tips that not many people know about? - Toddman_imp - 09-10-2015 Here's a tip from the roadracing side. Whatever you do to your bike, whether it's adjusting the chain to adjusting the valves, never ever walk away until that last bolt is torqued. I can't tell you how many times I've seen people (racers) stray away from what they were doing only to forget to tighten a bolt, nut or screw. Finish what you start. RE: What are some (uncommon) maintenance tips that not many people know about? - J.W._imp - 09-10-2015 Use paraffin to clean your chain, it is much kinder. RE: What are some (uncommon) maintenance tips that not many people know about? - 309antonios_imp - 09-10-2015 Chain Lubrication! Very important, and a lot of gentleman don't do it enough! What are some (uncommon) maintenance tips that not many people know about? - Josiah_Hurt_imp - 09-14-2015 Use Kerosene to clean your chain. Use a grunge brush and also use a grease ninja to lube. I can clean and lube my chain in 5 minutes or less. Sent from my iPhone using Tapatalk RE: What are some (uncommon) maintenance tips that not many people know about? - Birddogvet_imp - 10-29-2015 Kerosene= Paraffin= WD40. |
