Powercommander V Map Spreadsheet - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: Powercommander V Map Spreadsheet (/showthread.php?tid=4449) |
RE: Powercommander V Map Spreadsheet - Deanohh_imp - 01-11-2014 I don't use wot much but there's plenty of power everywhere. I dont expect huge acceleration at 70% anyway. If you had luggage or passenger a lot you might want a different map. The o2 sensor is out of the system. just that seems to make the ecu add fuel. And my setup is different than the others. The smallest thing can change what you need and it is not really predictable. if you look at the afr map, usually the tuning is done to target afrs around 13.2- 13.3 maybe. I see no point in richer if you get no power increase. The afr for us was secondary. In the various areas started leaner and added fuel for more hp. Added more file, more hp until added fuel returned no hp gain, then back a step. That's how mine was done. Response is excellent everywhere and at least as much as when using the stock pcv map with the higher numbers in some areas, which I ran for a while. I have a switch on the pcv to toggle between 2 maps and I run on the posted one now all the time. I would add that dynotuning is the only thing that this guy does. In addition to a shop in Seattle and one in Tacoma, his portable dyno goes to all the tracks in the NW for track days and club races. He knows track power and street power. He tunes hundreds of all makes per year. I don't question his results but if I thought there were any issues I would go back, explain my issue and he would correct it for free. RE: Powercommander V Map Spreadsheet - 12cb96vfr_imp - 01-15-2014 Hey Jon sorry buddy just saw this, yeah we did mine in 3rd and it hit the speed limit right at the top... RE: Powercommander V Map Spreadsheet - HondaJon_imp - 01-16-2014 Added the TSR map **ONLY 6 VALUES ARE DIFFERNANT THAN THOSE ON THE PRE LOADED PC V MAP** RE: Powercommander V Map Spreadsheet - INTP_imp - 03-08-2014 Does anyone have a map they can share for a bike with a TSR air funnel, K&N and an Arrow slip on? Thanks Kevin RE: Powercommander V Map Spreadsheet - 12cb96vfr_imp - 03-12-2014 mine posted has a slip on, k&n but no air funnel...not sure how much of a difference that makes.... RE: Powercommander V Map Spreadsheet - HondaJon_imp - 03-12-2014 INTP, The stock map that comes with the the PC V should be fine given your mods. I run the TSR map, which only has 6 values that vary from the map that is pre-loaded on the unit RE: Powercommander V Map Spreadsheet - VTR1000F_imp - 07-07-2014 Some time passed since last post. I wonder if there are newmaps so the original spreadsheet can be updated? RE: Powercommander V Map Spreadsheet - Mr Jangles_imp - 08-20-2014 I'm thinking of getting the PC V, my 2014 dlx is stock except for the K&N, do you think I can expect much improvement w/o changing the exhaust and just getting a stock map? RE: Powercommander V Map Spreadsheet - HikerToo_imp - 08-20-2014 Here is what the stock map does on the 2013, most people who have it agree it really fills-in the midrange that has been leaned out by Honda to meet emissions. The numbers above 0 represent % fuel increase at that RPM and throttle position.
RE: Powercommander V Map Spreadsheet - TINK_imp - 08-20-2014 Has anyone put a Powercommander on a 2014 CB1100 (Standard or Deluxe) yet? I asked Dynojet and this is what they said: From: Chris Kelly <ckelly@dynojet.com> To: "tinkler... Date: Mon, 4 Aug 2014 11:41:20 -0700 Subject: RE: Powercommander Customer Inquiry -- Sales I suspect that unit will work fine on your 2014 model; but we haven’t ever actually had a 2014 model in our possession to test it first-hand. Until then we cannot officially support the application. Let me know if you have any further questions. Regards, Chris Kelly Dynojet Research Inc. 2191 Mendenhall Dr. Suite 105 North Las Vegas, NV 89081 1-800-992-4993 |
