Powercommander V Map Spreadsheet
I created this spreadsheet to log any PCV maps anyone would like to share. If you would like to e-mail me your .PVM file to add it to sheet, just send me a message with you mods and I'll give you my e-mail address . I don't look for Dynojet to ever offer anything but the map that comes with the PC V. I'll add mine once my shop gets their heads out of their bums.
Awesome, very cool!
Thanks for sharing 12cb96vfr, it makes comparison pretty easy.
My gut tells me we are on our own. A one year run and all aftermarket parts coming from overseas, this forum will be the best reference around......
Looking at your map, I was surprised to see the 1250 boxes go from 0 to 15..... Pretty big change at low speed.
Did your shop have any issues with the speed limiter? Mine acts like they can't tune it right without it being disabled...
Thanks Jon!
+1, Thanks a bunch.
Back in the day I was at a dyno once a month, living out here makes it tough now. I will get to one this summer for a tune run on my mods. This helps alot until then Beer
Hey All,
Just added Deanohh's map to the sheet.
This could get interesting.
Hmm....where did Deanohh' map come from? Are those numbers % change from OEM or base map from factory? Does not seem like it is doing much...
(01-11-2014, 10:08 AM)HikerToo_imp Wrote: Hmm....where did Deanohh' map come from? Are those numbers % change from OEM or base map from factory? Does not seem like it is doing much...
I told Nels it ran jerky at low speed steady throttle. I wanted a safe afr but have some economy when cruising and max power on demand... The map is the result.
Like all pcv maps its the % added or subtracted from the fuel map built in to the bike.
Yes, but it doesn't do much in all the right places.
"Sometimes nothing can be a real cool hand."
"Sometimes nothing can be a real cool hand." So how often are you in the 80 to 100% throttle where your PCV kicks in? I see most people trying to beef up their low and mid range, in the usable power range....
  CB1100 Idle Speed Instability—Link to Spreadsheet Cormanus 0 224 08-01-2017, 12:09 PM
