Deanohh_imp
Been there
well when on a dyno, I unplugged the sensor wire right there by the air box and the bike went into some kind of safe mode.... Wouldn't go above about 6k in any gear. On my bike that does not defeat the speed limiter. Plugged back in and would get to about 9k in 3rd to get a map for upper rpms. Btw after mapping, max pwr 91.6, torque 69.7.Deanohh_imp said:You can unplug the speed sensor if you don't mind getting an error code and check engine light, and no Speedo or odometer.
Staintune slip on, dome cut off snorkle with stock paper filter, pair hose blocked, power commander v.
