johnnyH_imp
First service completed
Hi Guys, I have replaced the rocker cover gasket on my 2010 CB1100 and decided to take apart the reeds (unsure what they are actually called) to see what they are and clean them, As you guys will be aware to get the rocker cover off I had to take out the coils and remove a few other things, well I have put everything back together and triple checked the plug lead order and coil wire order but the bike is idling fairly smooth except it backfires when revved, I went back to google and looked at a wiring diagram to check I have the wire in the correct position and can't find a fault, could it be I have those reed valves in backwards? would that cause a backfire when it's revved or am I missing something with the coils etc, many thanks
