Hepco Becker Replacement Key
tomcat_imp
First service completed
Recently bought two used HB top cases. Not a fan of the plastic headed keys that HB has and would like to replace them. Looked at several Ilco keys, none of which is a replacement. Moto Machines has HB keys but 1 key is ~ $25 shipped and is the large plastic head key. Anyone know of key blanks or a source for replacement keys?
Agreed.
Can you smash up the red plastic shroud and drill a nice hole into the key? Or is the "Hepco & Becker" logo portion of the key independent of the key blade?
I am wondering if the extra plastic shroud provides leverage on those tough days when the tumblers are feelin' extra resistive?
GoldOxide_imp said:
Agreed.
Thought about trying to grind, cut, or burn off the red plastic and drill a hole in the metal head. Searched to no avail for a key blank. Pain putting these types of keys on a key ring. Fortunately blanks are available for the big head CB1100 keys.
tomcat_imp said:
GoldOxide_imp said:
Agreed.
Thought about trying to grind, cut, or burn off the red plastic and drill a hole in the metal head. Searched to no avail for a key blank. Pain putting these types of keys on a key ring. Fortunately blanks are available for the big head CB1100 keys. tomcat, first you might check with a local locksmith. Sometimes they are your best resource. If they don't have it, then you might have to get creative. Good luck
Nachodaddy_imp said:
tomcat_imp said:
GoldOxide_imp said:
Agreed.
Used a Dremel to remove plastic shroud. Drilled a hole which also removed the HB logo. Not pretty but it's better.
