Fehling saddlebags support and signals relocation
I believe if you look in Romos thread, VFR Paul listed type and retailer of the correct size connectors for the CB
I finally got to install of the saddlebags support and ran into a problem. They can´t be installed without relolocation of the indicators. Rear bracket with thru-bolt is too long and collides with indicator chrome housing.
For those who already relocated their signals - what is the cleanest approach? Disconnect them under battery tray (where the connectors are located I suppose), and put some kind of pigtails between original indicator loom and main loom? Or disconnect the wiring inside the indicator housings and go from there?
I´m coming from VW Beetle world and I´ve seen all kind of mechanical and electrical hacks on these poor cars..I like to keep everything factory looking or at least returnable to factory condition.
Thank you!
I like the Fehling products shown but it has so far been a hassle to procure and install. There are two products shown in the picture. The "luggage carrier" is the top rack that extends over the tail light and the "baggage holder" which is the U shaped tubing on both sides. They are sold separately and the 2013 luggage carrier does not fit the 2014. If fact it is in redesign and when available it will be made to fit either the 2013 or 2014. You can find these products at the Fehling.de website. Note that the turn signal relo hardware is included with the "baggage holder".
Regarding the turn signals I have decided to remove the originals (which come out all the way from the connectors near the battery) and replace them with the smaller but brighter X-Arc Yellow Chrome which can be found here: hightechspeed.com — Coming Soon
I found replacement orange and blue connectors that will allow me to keep the original turn signals with the wiring in the event I ever want to put them back. They can be spliced ot my new signals and can be found here: POSH : Turn Signal Conversion Cord Set [091675]
