Installed! The 16mm long license plate screws were a bit long for mine. A lock washer on one side, with the flat washer on the other side, fixed it. Kenny, thank you again for a much more elegant mount than the OEM.
The license plate frame makes the 16 mm screws just right for acorn nuts. Otherwise the next step down is typically 12 mm long screws. I think adding the extra washer was the better way to go than a shorter screw.
For those wondering why this thread is bouncing around the forum, the rules require that classifieds be deleted when done with or after a couple of months.
There's some technical information in here worth preserving so I moved it to the members' products section. kennyw then pointed out that he'll be making no more of them, so it's in here now.
