My Sincerest Apologies to All the Red DLX Owners
metallyguitarded_imp Offline
Threads: 62
Your dominance has officially come to an end.
[url=http://s51.photobucket.com/user/jamesfontaine/media/Mobile%20Uploads/IMAG1368.jpg.html][Image: aac0f75d2801bf9b402901c371d8f3c3.jpg]
12-27-2014, 06:07 AM
Rocky_imp Offline
Threads: 26
RE: My Sincerest Apologies to All the Red DLX Owners
You've got lever "thingies"!!! Banana
12-27-2014, 06:10 AM
Likes Received: 619 in 277 posts
Likes Given: 789
Now, yours will officially be a CB Wink
12-27-2014, 06:11 AM
Powerdogg55 Offline
Jackson , Georgia
Threads: 8
Your CB is complete.
12-27-2014, 06:14 AM
Citius, Altius, Fortius
12-27-2014, 06:27 AM
Threads: 62
Thank you gentlemen. Install is complete. At first, I thought, "You have got to be kidding." Persistence pays off, however, and after I learned the proper technique on the first lever, the second RLET went on relatively easily. What technique is that, you ask? I believe each man must walk his own path on the journey towards CB salvation.
Okay, fine. Twist my arm, why don't you? I sprayed just a dab of WD-40 on the inside of the RLET, used a shop rag to grip the RLET, and with the opening rounded onto the end of the lever, I pushed straight onto the lever. No twisting. Just a straight push onto the lever. This put the RLET about half-way onto the ball end of the lever. One more push and slight twist and the RLET was installed. The first one took me a few minutes to figure out. The second one went on in about five seconds.
12-27-2014, 07:22 AM
DGShannon_imp Offline
Threads: 29
Getting those things on was almost as much work as the fork gaiters! Tricky little devils.
12-27-2014, 07:23 AM
Likes Given: 789
(12-27-2014, 07:22 AM)metallyguitarded_imp Wrote: Thank you gentlemen. Install is complete. At first, I thought, "You have got to be kidding." Persistence pays off, however, and after I learned the proper technique on the first lever, the second RLET went on relatively easily. What technique is that, you ask? I believe each man must walk his own path on the journey towards CB salvation.
go ahead and admit it , bike looks better now, doesn't it! Thumbs Up
12-27-2014, 07:35 AM
Threads: 62
Once again, you're right. Don't you ever get tired of that? Must be exhausting.
12-27-2014, 07:38 AM
Django Offline
Threads: 71
Likes Given: 20
Hm, until now I've thought, it's as simple as putting 'em into really hot water to get 'em weak and just push them over the lever?!
May be, I should be more daunted by RLETs. Have to get some...
12-27-2014, 07:54 AM
  Corbin owners, would you have it made differently? Ollie 29 2,161 06-12-2022, 12:15 AM
Last Post: Ollie
  Question for '17 EX/RS Owners Flytech99_imp 14 1,035 03-09-2019, 06:44 AM
Last Post: will866_imp
  Chip Beck Corbin Seat owners iamlegend21087_imp 6 548 08-29-2018, 07:12 AM
Last Post: bflint
  Honda OEM(Japan) topcase owners iamlegend21087_imp 3 429 06-25-2018, 04:30 PM
  Endurance Rack owners: I need help Frulk_imp 2 308 05-31-2016, 08:04 AM
Last Post: Frulk_imp
  ChicDesign short rear fender owners - tried or considering this? Riko_imp 15 1,157 10-10-2015, 02:01 PM
Last Post: Rebel73_imp
  New possibilities for 2013 and older CB1100 owners? Guth_imp 25 1,515 02-21-2014, 11:51 PM
Last Post: Honda Lover_imp
  Phoenix Custom seat owners rboe 2 233 10-30-2013, 04:24 AM
Last Post: rboe
