Three low cost farkles
Captain Klutz_imp Offline
Threads: 6
I recently added three low cost farkles to my EX.
The analog oil temperature meter adds a bit of steam punk style; then I took a small brush and gold spray paint and had a go at the rings of the brake disks. Makes them look expensive!
Note that the bubble in the glycerine (to absorb the vibrations) is there on purpose so the glycerine can expand and not break the glass. This is the thermometer with the 6mm stub facing inwards.
What a 6EUR gold spray paint and a brush can do... I was careful not to overdo it in case I wouldn't like the result. But it turned out great, especially in the sun. Maye I should have a go at the ABS sensor wheel...
In the German CB1100 forum someone offered stickers in Japanese reading "Designed by Mitsuyoshi Kohama" but I believe I've been scammed and they actually read "This rider was ripped by Honda". Big Grin
07-18-2014, 05:56 AM
DAC Offline
Threads: 17
Likes Received: 12 in 6 posts
Likes Given: 12
RE: Three low cost farkles
Nice!
Oil temp gauge is especially interesting. Where did you get it and does the 6mm stub just read the oil flung off the clutch?
07-18-2014, 06:24 AM
Threads: 6
(07-18-2014, 06:24 AM)DAC_imp Wrote: Nice!
I got it from http://www.biketeile-service.de/en/frame...79040.html
The manufacturer ID is BH12-0314, EAN: 4043981006827. Yes, I believe it's mostly the oil flung around (I'm not a mechanic, so don't take my word). And certainly also contact with the casing. It takes a long time to fall back to 20 when the casing is hot after a ride.
On my 45min rides it goes up to 80 degree celsius and mostly stays there, even in hot weather. I'm not a hotspur and rev the bike mostly between 3 and 4000. The air/oil cooling obviously works great!
07-18-2014, 07:12 AM
dUh!_imp Offline
Threads: 15
Harley V-Twin riders around here run with digital oil temp gauges. I have been looking for them with no success. Thank you for finding an option. Have to keep that link.
07-18-2014, 07:29 AM
Pauley Offline
Walnut Creek, CA
Threads: 14
Likes Received: 14 in 9 posts
Likes Given: 20
Thanks, Cptn Klutz! My favorite Mad character BTW.
I especially like the oil temp gage - I book marked it. I may steal your idea and add one to my bike. I like gages.
07-18-2014, 09:44 AM
furious_blue_imp Offline
Threads: 11
Great ! My farkle list is pretty small. This is definitely added to my list.
07-19-2014, 02:45 AM
CB4ME_imp Offline
Threads: 183
I think the brake discs look great! Very refined farkle. Did you pull the wheel off to paint then?
07-19-2014, 05:39 AM
Threads: 6
(07-19-2014, 05:39 AM)CB4ME_imp Wrote: I think the brake discs look great! Very refined farkle. Did you pull the wheel off to paint then?
No need to pull the wheel off. Spray the paint in a small container, then use fine (2mm) brush and apply paint on ring and the inner cylindrical surface. I didn't bother to paint the far side of the ring; it's next to impossible to reach past the brake discs and between the spokes, as you can see here:
The result in toto:
Farkled now with:
* Big fat 2013 chrome meter covers crammed to fit 2014EX
* Chrome headlight case
* Kawasaki W650 gaiters
* Fenda Extenda
* JMP analog oil temp gauge
* Painted gold brake disc connector rings
* "Designed by Mitsuyoshi Kohama" sticker
07-19-2014, 06:31 AM
CB4ME_imp Offline
Threads: 183
Captain,
I applied your front disk brake farkle to my 2013 non-ABS bike:
[Image: 031758773488ee1afe552755b828b157.jpg]
It was a very easy farkle. Use a T30 torx bit to remove the bolts and remove the collars. Clean, prime, paint the collars and reinstall.
Once done, I ordered a 38T rear sprocket in matte gold from Mt T. to add some color to the rear.
Big Grin
09-02-2014, 05:04 AM
Threads: 6
(09-02-2014, 05:04 AM)CB4ME_imp Wrote: Captain,
Big Grin
Well done, CB4ME. Now we have two role models for STD and EX. May the GBDR catch on like the RLETs. Smile
03-04-2015, 08:21 AM
  Common CB1100 Farkles TooManyBikes_imp 6 731 04-06-2024, 11:47 AM
Last Post: CB for CST_imp
  Preferred Brake Light Bar Farkles TooManyBikes_imp 12 1,460 03-18-2024, 02:46 AM
  the true cost of tires j3gq_imp 20 1,263 10-20-2021, 03:24 AM
  Lowered bike and it didnt cost me an arm and a leg.. Coltnut_imp 16 1,196 08-25-2019, 03:36 PM
  New Farkles BigSky_imp 18 1,316 04-20-2017, 07:42 AM
  Three new farkles CB4ME_imp 20 1,321 08-05-2016, 11:00 AM
Last Post: dsan1964_imp
  The thing about mods and farkles the Ferret 25 1,510 05-30-2016, 05:13 AM
Last Post: ChipBeck_imp
  staintune direct cost crutch_imp 2 293 05-08-2016, 05:17 PM
  Two New Farkles CB4ME_imp 4 534 08-25-2015, 09:24 PM
  Farkles for Katie! ThomWill_imp 38 1,940 07-28-2014, 03:51 AM
Last Post: Chucky_imp
