Electrical Question
White Dog_imp Offline
Threads: 59
Electrical Question
Someone mentioned there is a red plug inside the headlight bucket which is "hot" with the switch on. does it also have a ground wire moulded into the plug as well? I'm thinking I might have to use that plug to install a plug for a radar detector. If no ground connection in the plug, where would I attach the ground wire?
09-03-2015, 12:14 PM
kmoney_imp Offline
Threads: 29
RE: Electrical Question
It's a two-pole with power and ground. Someone on here posted in a other thread a correct link to the Sumitomo connectors that will fit it if you don't want to cut wires.
09-03-2015, 12:18 PM
  LED'Ss and other Electrical Q's edd_of_the_hill_imp 7 639 07-21-2017, 09:18 PM
