Threads: 20
Back in January I was having some probs with my right eye blacking out. Saw a couple of doctors but as the problem was intermittent no-one seemed to know what was the cause. I ended up driving up to far north Queensland and did some fishing and visited my daughter. When I got home there was a few messages from my doctor to come and visit him asap. The results of my MRI showed that I had a blocked carotid artery and my symptoms were what is known as a TIA. Went straight to hospital and had a carotid Endarterectomy on my right side. All fixed now and just a check up late next year. I have been clocking up some kilometres in the last couple of months and just put a set of Dunlop Arrowmax tyres on the CB. I went for a 150 on the back and if the weather ever cools off a bit I'll be able to see how well they handle.Now that my maintenance has been done I intend to replace the chain and sprockets and do the valve clearances on the CB. It has just hit 60k kilometres.
![[Image: bdef7faf34a2055b66803dc11c523f0f.jpg]](https://cb1100forum.net/forum/uploads/imp/201911/bdef7faf34a2055b66803dc11c523f0f.jpg)
More plumbing than a suzuki 2stroke oil pump.
![[Image: 9b7ea7aa8457f42f46033b4d493abf88.jpg]](https://cb1100forum.net/forum/uploads/imp/201911/9b7ea7aa8457f42f46033b4d493abf88.jpg)
Nice zipper on my neck.
Likes Received: 580 in 317 posts
Likes Given: 971
Doesn't look good but look is not important.
Wish you speedy and permanent recovery, so you can enjoy your CB in upcoming Australian summer. Good luck!
Threads: 81
(11-25-2019, 11:02 AM)Tezza_imp Wrote: Back in January I was having some probs with my right eye blacking out. Saw a couple of doctors but as the problem was intermittent no-one seemed to know what was the cause. I ended up driving up to far north Queensland and did some fishing and visited my daughter. When I got home there was a few messages from my doctor to come and visit him asap. The results of my MRI showed that I had a blocked carotid artery and my symptoms were what is known as a TIA. Went straight to hospital and had a carotid Endarterectomy on my right side. All fixed now and just a check up late next year. I have been clocking up some kilometres in the last couple of months and just put a set of Dunlop Arrowmax tyres on the CB. I went for a 150 on the back and if the weather ever cools off a bit I'll be able to see how well they handle.Now that my maintenance has been done I intend to replace the chain and sprockets and do the valve clearances on the CB. It has just hit 60k kilometres.
Got through it ...... good for you!
Bob
Likes Received: 596 in 265 posts
Likes Given: 771
Chicks dig scars.
Geez glad they found out what the problem was and got you fixed up Tezzza. Any long term ramifications?
Never heard of that particular problem. Good to know there is something else to worry about lol.
Threads: 7
heal quickly, ride when you can, celebrate survival.
Jim
Impressive proactive response. Glad to read about the recovery.
If I had met you without knowing anything, you could tell me any story and I'd believe it.
Threads: 16
Likes Received: 4 in 3 posts
Likes Given: 19
G'day Tezza, good the blockage has been sorted and your feeling better.
When you do the valve clearance check please let us know how it went and add you findings to Pterodactyl valve clearance table.
Regards NRTM
Threads: 119
Likes Received: 806 in 340 posts
Likes Given: 800
Wow, that's a serious slice on the neck! Glad you're on the rebound. Good luck with the maintenance items coming up. Has anyone done a "how-to" for chain and sprocket replacement? Here's your chance!
Threads: 20
My neck has healed up really well and it is well camouflaged by the other wrinkles. They had to cut a nerve to get to my artery so the right side of my neck and my chin are still numb. It could take up to 9 months to repair so shaving is a bit awkward. I have found the biggest problem is the statins I have to take now make my leg muscles a bit shaky so I have to be careful when maneuvering the bike.
Threads: 347
Likes Received: 857 in 470 posts
Likes Given: 986
Geez, Tezza! I was thinking about you the other day and that we should organize a ride. Glad to hear you’ve got through that OK. Best wishes for a continuing recovery.
I’m interested: why did you a 150 on the rear rather than the 140?
