Loose bar ends?
Brant_imp Offline
New to the Forum
Threads: 1
Loose bar ends?
I've noticed that after the engine is under load that the handle bar ends vibrate and turn. The salesperson stated this was normal. Any input?
08-12-2013, 08:35 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Received: 200 in 118 posts
Likes Given: 142
RE: Loose bar ends?
Read this and most likely your question will be answered!
http://cb1100forum.com/forum/showthread.php?tid=980
08-12-2013, 08:59 AM
Brant_imp Offline
New to the Forum
Threads: 1
RE: Loose bar ends?
(08-12-2013, 08:59 AM)Lord Popgun_imp Wrote: Read this and most likely your question will be answered!
Beautiful, thank you for the swift reply!
08-12-2013, 09:13 AM
Deanohh_imp Offline
Threads: 5
RE: Loose bar ends?
You mean is the vibration normal or that the weights turning is normal????
08-12-2013, 09:34 AM
ChipBeck_imp Offline
Threads: 29
RE: Loose bar ends?
(08-12-2013, 09:34 AM)Deanohh_imp Wrote: You mean is the vibration normal or that the weights turning is normal????
Deanohh,
The bar end weight on the throttle side turns so if your hand is too far out while you are twisting the throttle the bar end will turn with the throttle. The one on the clutch side does not turn. If you don't want it to turn freely, grab the weight and tighten the Phillips head screw in the end of the bar weight. They can still be forced to turn by rotating the entire weight assembly inside the two rubber doughnuts that are wrapped around the ends of the interior weight.
Chip
08-12-2013, 10:52 AM
Deanohh_imp Offline
Threads: 5
RE: Loose bar ends?
Thanks, I couldn't figure exactly what the OP wanted to know.
08-12-2013, 11:27 AM
Brant_imp Offline
New to the Forum
Threads: 1
RE: Loose bar ends?
(08-12-2013, 11:27 AM)Deanohh_imp Wrote: Thanks, I couldn't figure exactly what the OP wanted to know.
I just thought it was odd, problem solved.
08-13-2013, 09:34 AM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
RE: Loose bar ends?
Deanohh,
Chip
Deanohh,
Chip
I saw this and tested it on mine.....it didn't turn/move. Hmm.....
08-18-2013, 08:48 AM
Birddogvet_imp Offline
Threads: 1
RE: Loose bar ends?
I actually had one fall off on another bike (Suzuki) of mine. Not inexpensive to replace.
Your options are 1. to remove and plug 2. blue Locktite in place 3. screw them down and check ever so often.
I chose the later and so far so good.
10-27-2015, 11:50 PM
  loose the arrow jimgl3_imp 33 2,298 08-30-2021, 11:14 PM
  Rizoma Bar End Mirrors w/ Stock Bar Ends? cb1100_dude_imp 2 400 09-04-2018, 04:06 AM
Last Post: cb1100_dude_imp
  Threw on Rizoma grips and bar ends. silascopathic_imp 9 842 06-01-2018, 02:23 AM
Last Post: Mandrau_imp
  Chrome/Stainless bar ends Chris Goldson_imp 10 701 11-19-2017, 04:56 AM
Last Post: 2017EX_imp
  Engine Guards and Bar Ends metallyguitarded_imp 57 3,557 04-24-2015, 06:08 AM
  '14 Deluxe chrome bar ends on '13? pechorin75_imp 6 511 09-02-2014, 12:33 AM
Last Post: jlhalsey_imp
  Ordering OEM Silver Bar Ends??? redReno_imp 1 190 07-04-2013, 03:47 AM
Last Post: HondaJon_imp
