Highway pegs/sliders question
What I think I might like to do: add highway pegs to my bike that are strong enough to protect my bike in the event of a drop OR add sliders that are long enough and positioned in a manner in which they could serve as highway pegs.
What I don't want to do: fabricate mounting plate or brackets. Add crash bars.
Any thoughts, links, or pics on this subject?
Thanks!
01-27-2015, 03:10 PM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
RE: Highway pegs/sliders question
Have you seen the "crash bars" on my bike?
01-27-2015, 05:55 PM
Yes, and they look great, but I think I'm primarily looking for a extra place to put my feet that may have the secondary benefit of protecting my bike in a fall. I'm picturing something like a set of very long frame sliders bolted to or clamped to the frame. I've looked around here and the Internet and haven't had much luck in zeroing in on anything yet.
01-27-2015, 10:06 PM
4845mike_imp Offline
Threads: 2
(01-27-2015, 03:10 PM)EmptySea_imp Wrote: What I think I might like to do: add highway pegs to my bike that are strong enough to protect my bike in the event of a drop OR add sliders that are long enough and positioned in a manner in which they could serve as highway pegs.
Thanks!
01-28-2015, 12:50 AM
the_undecider_imp Offline
Threads: 43
I have the Moriwaki sliders I purchased from Mr. T. They stick out enough for me to put my feet up on them, but are too slick to offer a secure footing. Replacing the slider portion with something grippier might work, but would like impact the effectiveness of the slider. Clamping a set of pegs like Kuryakens would achieve only half of your objective since they'll fold up and not protect anything in the event of a tipover.
I think the SW Motech engine guards look the best since they blend with the frame tubes. You can then attach highway pegs to the guards. Twisted Throttle sells the guards and brackets/pegs:
http://www.twistedthrottle.com/sw-motech...-cb1100-13
01-28-2015, 02:31 AM
Papa Weeley_imp Offline
Threads: 44
Although I'm not really a highway peg kind of guy, I've often thought - like the_undecider - that due to both size and position, my Moriwaki sliders would work well for that, too. As he mentioned, wrapping them with something with more grip would be necessary, but I think they could handle both jobs nicely, and would be a whole lot cleaner looking than the usual steel tube type engine guards with pegs bolted on.
01-28-2015, 03:01 AM
kevbroce_imp Offline
Threads: 6
I use my Moraki's as foot rests time to time. Problem is they put you legs pretty close to the engine so careful what your pants are made of. Jeans are fine but you might melt a hole in some textiles. They are slick, but depending on your boots it might not matter. A little skateboard grip tape or something similar would easily fix that. They aren't a good position for long stretches road, its a kinda awkward position for me at least, but just having a slight change in positioning for a bit goes a long ways. Most often I find myself using them with one foot on the foot peg and the other on the slider. Between the sliders and passenger pegs I've found there's lots of different ways I can stretch out.
01-28-2015, 04:04 AM
I like the Morakis. I wonder if I could get a longer bolt or even a longer slider (with a longer bolt) or something to get more clearance for my foot. Thank you for pointing me in a good direction for my search. Smile
01-28-2015, 05:37 AM
Threads: 43
A longer bolt and some sort of spacer to mount between the slider and the bracket might do the trick.
01-28-2015, 06:56 AM
drswan92028_imp Offline
Threads: 2
Thanks!
I made my own brackets real easy and added Kuryakyn Large ISO-Pegs. Two holes for the mounting bolts that are already on the bike and one for the pegs. I painted them black and make sure you put heavy lock tight on the bolts or the pegs will loosen.
Dave
01-28-2015, 01:17 PM
  Exhaust Sliders for CB1100EX (World Walk) rdprdp01 2 281 05-13-2026, 05:40 AM
   Foot pegs Nick_imp 3 429 01-02-2025, 04:14 AM
  axle / frame sliders dlm1100_imp 9 951 06-02-2023, 10:41 AM
  3D printed strap adapters for the CB1100 mounting pegs LayerCake_imp 33 2,334 07-10-2022, 12:04 AM
Last Post: 1973cb750
  R&G front axle sliders gretle_2.0 11 1,171 06-14-2022, 03:49 AM
  Frame sliders/engine guards Cqrlm911_imp 81 4,963 11-10-2021, 06:46 AM
  Help me find parts to mount highway pegs please LikeAfox_imp 23 1,774 05-24-2021, 10:03 PM
Last Post: LikeAfox_imp
  New Seat, Pegs, etc. aschem_imp 16 1,261 10-14-2020, 01:02 PM
Last Post: dhubbard422_imp
  Bar End Sliders GroovyBunny86_imp 9 861 04-29-2020, 02:10 AM
Last Post: GroovyBunny86_imp
  Side sliders AsHperson_imp 6 1,119 10-26-2019, 11:53 AM
Last Post: AsHperson_imp
