pull back
Southwend Offline
Von Zipper
Clarksville Virginia
Threads: 29
Likes Received: 8 in 4 posts
pull back
with the addition of my Corbin seat I need about an inch more height on my handlebars to allow me to straighten my back out. The problem is that my fairing uses the risers as a mounting point so I must change the handle bar. I assume the factory is about 4 inches? Any subbestions where I might find what I need?
02-23-2016, 02:47 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Received: 180 in 103 posts
Likes Given: 121
RE: pull back
How about a pic of the way that fairing is mounted. There are risers that mount on the OEM riser. Maybe you could sandwich it or something. There are pics of this type of riser on the board. I'll look later if you want.
02-23-2016, 04:43 AM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
RE: pull back
Check out Rox risers (amazon.com is one source) to see if they would help.
02-23-2016, 03:07 PM
Southwend Offline
Von Zipper
Threads: 29
RE: pull back
I looked at it and thought the same but did not think such a solution was available. The fairing ahs supports to the top of the riser so some sort of sandwich would be a good solution.
(02-23-2016, 04:43 AM)Lord Popgun_imp Wrote: How about a pic of the way that fairing is mounted. There are risers that mount on the OEM riser. Maybe you could sandwich it or something. There are pics of this type of riser on the board. I'll look later if you want.
that would be great, thanks.
02-24-2016, 06:07 AM
Lord Popgun Offline
Virginia
Likes Given: 121
RE: pull back
Well if you search on risers a ton of stuff comes up but I cannot find the one I was thinking of.
However, the 2 links below show an interesting design that might work for you. Check them out and see what you think. The second link shows a good top view pic.
Post up your pic if possible. There are some really smart members here. Someone will have a solution.
http://cb1100forum.com/forum/showthread....s#pid18731
http://cb1100forum.com/forum/showthread....#pid122422
02-24-2016, 07:22 AM
Redbird_imp Offline
Threads: 7
RE: pull back
southwend, I seem to remember that you have a Parabelum Scout fairing. That is what I have mounted to mine and I am using a Twisted Throttle SW Motech riser http://www.twistedthrottle.com/handlebar...1-pullback
I had to use a nut as a spacer (the forward mounting bolt needs to be able to slip through it) to allow the fairing mount to lay flat, works fine and gives me enough pullback. You could also modify the riser so that the front mounting area is flat. If I am right about your fairing, let me know and I'll put up a picture of what I'm describing here.
Ken
02-24-2016, 05:23 PM
Southwend Offline
Von Zipper
Threads: 29
RE: pull back
looks like the gen mar x-103/x-104 is the sandwich style riser. 7/8" work?
02-24-2016, 10:56 PM
Ron in MO_imp Offline
Threads: 14
RE: pull back
The GenMar are the ones I bought for my CB and they should work with the sandwich solution you are looking for. 7/8 inch is the correct size handlebar.
[url=http://s1376.photobucket.com/user/ronsteinbruegge1/media/2016-01/00000000-0000-0000-0000-000000001A4F_zpsd9l6m5yh.jpg.html][Image: 2b0afc9eb20a0be78e1b50761fa6a90a.jpg]
02-25-2016, 12:02 AM
Southwend Offline
Von Zipper
Threads: 29
RE: pull back
(02-24-2016, 05:23 PM)Redbird_imp Wrote: southwend, I seem to remember that you have a Parabelum Scout fairing. That is what I have mounted to mine and I am using a Twisted Throttle SW Motech riser http://www.twistedthrottle.com/handlebar...1-pullback
Ken
You are spot on, parabellum.
I figure an inch back should work as a minimum. A bit more would be better. However I am concerned about using up what little play is available in my brake/throttle cables.
02-25-2016, 01:27 AM
Southwend Offline
Von Zipper
Threads: 29
RE: pull back
At the twisted throttle site I found a set of ROX 7/8" risers that will allow me to keep the stock risers in place as well as have more options for pivoting. The question is how much rise can I get away with before I run into cable issues?
I was riding the other day and would sit back and carefully pull my hands off the grips, amazing what a difference in rider geometry 1-2 inches makes. The pressure comes off of my wrists and my back straightens enough to stack the force rather than place it at the pivot in the small of my back. Hard to be accurate but I think the 1.25-2 inch range is where I need to be.
02-25-2016, 02:52 AM
